Another Intermittent Headlight Thread
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ru5real, Oct 18, 2013.
  1. ru5real
    ru5real Junior Member
    42
    Hi. Recently bought a used '04 and having the intermittent headlight issue. From having done limited research, I guess I'm supposed replace the bulb first. I realize it's best to try cheaper solutions first, just wanted confirmation that replacing the bulb actually solved this issue for anyone.
    Just sounds hokey that it's actually a bulb problem, or is this just a cheaper/temporary work around to an expensive problem? Even if it works, should I expect frequent bulb replacements?
    Could ya'll share your experience? Has anyone only had to change out their HID bulb once? Thanks in advance
  2. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Had the intermittent problem, changed bulbs (Phillips from Amazon). No further issues.
    ru5real likes this.
  3. ru5real
    42
    How long ago was that? Thanks.
  4. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
  5. ru5real
    42
    Ok
    Ok, Thanks.
  6. DGH
    365
    93
    Wales, WI
    About four years and 100000 miles ago.
  7. ru5real
    42
    Wow. That's good to know. Thank you.
