Another oil question
Discussion in 'Gen 4 Prius Technical Discussion' started by tedblais, Apr 13, 2022.
  1. tedblais
    tedblais Junior Member
    So I went to a new shop today looking to change my oil on my 2017 Prius. I brought my own 5W 30 which I believed was the best choice for where I live - So Cal.
    He called me back a few minutes later saying that 0W 20 was the only oil that would work because the high pressure fuel pump needs thinner oil to cool the fuel pump. Any other oil would void the warranty, which I'm not even sure I have anymore.
    Is this true?
    Thanks!
    49,490
    isn't the fuel pump inside the gas tank like other gens?
    maybe he meant the oil pump :unsure:
  3. BiomedO1
    BiomedO1 Senior Member
    1,474
    796
    SacTown, Ca
    No, I think it's the muffler bearings:LOL::eek: Just kidding...
    I believe the OEM calls for 0W20 oil. Why are you using that "thick" oil? Do you have oil burn issues? Your mechanic is correct, your warranty may be voided if they find out you were not following OEM recommended guidelines. At the same time your mechanic is incorrect; good quality 5w30 will run fine in the car as long as temperatures stay well above freezing. You may loose a few mpgs because of the added resistance created by the thicker oil.
    I had oil burn issues on my old PriusC, once I got over 60k miles. It burned about a quart every 10K miles. I've had worse; but it irked me. I switched to 5W20 and the oil burn slowed to less than a pint every 10K miles.
    I believe your power-train warranty is 5 years 60K miles, so your just outside warranty. The EV portion of your warranty is still in effect 10 year 100K.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Same engine - but 2016 PRIUS Manual - in AUSTRALIA:
  5. BiomedO1
    1,474
    796
    SacTown, Ca
    Yea, but the USA manual doesn't give us that kind of oil options. I'm too lazy to post a copy of our manual, but our maintenance manual clearly states that 0w20 is what your suppose to use, and your allowed to use a different weight in an emergency and that it must be changed back to 0W20 on the next service interval; which is 5K miles apart, not kilometers.:D
    BTW; you've got some smudging, going on in that picture "NOT FOR REPRODUCTION" :D:LOL::ROFLMAO::whistle: (it's a joke; don't take me seriously). I did mention that his mechanic is wrong. The OP could probably ship the car to Australia to get the warranty work done, since the oil he's using is valid over there. ;)
    #5 BiomedO1, Apr 13, 2022
  6. alanclarkeau
    7,044
    7,584
    It's seriously weird. We get a 7 year drivetrain warranty, but have to do 10,000km services.
    Oil - that's fairly common here - as in the middle of Australia, temps are very different from in the Alpine areas.
    BUT then - the USA isn't any different - I imagine the difference between the Arizona and your snowbelt is even greater - but you only have the one oil to "choose".
  7. Mendel Leisk
    38,726
    And then, a year or two further into gen four Toyota in North America has gone to 0W16; basically edited the owners manual thus:
    5W-20 < 0W-20
    0W=20 < 0W-16
    You may be right. FWIW, for 2nd gen Prius Toyota in North America spec'd that oil. But yeah, maybe just stick with 0W20, to avoid "rocking the boat".
    Another thing to consider: stick with 6 month or 5K mile interval for the change. It is recommended for "severe service", if you need justification.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,470
    1,514
    NJ-USA
    Gasoline Direct Injection engines can/will have problems with longevity if you don't use oils that meet the OE specs. There it's more of "what anti-wear additives" are in this oil vs "what viscosity" is it? Oil quality is key for any engine. Walmart synthetic might be adequate for some "old school" designs - if you keep relatively short OCI. For GDI, fancy multi-chain cam drives, or extended OCI, then you need to do some homework on what you're putting in the crankcase.
    That said, in the US I'd expect that they only have one spec because of MPG ratings. I also think that many shops only use the "recommended" oil as a CYA policy. They don't want to be paying for some Euro-car engine after an oil change "because" they didn't use the OE oil and it gackked 15k later.
  9. ETC(SS)
    6,555
    See that light?
    It's the "Change Mechanic Soon" light......
    I disagree with your reasons for wanting to club up to 5w30, but in the end it's not going to matter very much one way or the other.
    The G4 is liquid cooled and thermostat controlled which pretty much means that the temps where the oil is hanging out are going to be at or near 195-200-degrees F whether you're driving in the inhospitable frozen North (say...anything above I-20) or creeping along on the scorching asphalt in one of America's urban deserts.
    Either way....if your mechanic told you that the (electric) fuel pump is oil cooled then you need a new mechanic.
    SOONER rather than later.
    Good Luck!
    (where YOU live, you're going to NEED it!) :p
    alanclarkeau likes this.
  10. bisco
    49,490
  11. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    IMO giving a mechanic oil and or filter to install is a waste of time effort and money. Mechanic will use whatever they are going to use, anyway. How would you know the difference?
  12. bisco
    49,490
    and she'll take your oil home for her personal use :p
    vvillovv likes this.
