Another - Parking brake ABS/VSC lights 06 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jm98, Feb 18, 2018.
  1. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Just got dreadful ABS warning light and parking break light.. Looks like it's here to stay permanent in 2018.
    This started is exact 48 hours after simple oil change trip to local toy dealer.
    49,709
    what the code? could be they drained your 12v.
  3. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Just got techsteam so will be reading codes as standard OBDII not showing codes. I am hoping it's 12v issue but it not likely.
    Raytheeagle likes this.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Test the voltage of your12v after a full night's rest and report it here.
  5. ChapmanF
    15,886
    If you've read enough threads here to call your new one "Another" brake ABS/VSC lights, you've probably seen you can get brake codes by counting dash blinks, any time you're caught without ready access to Techstream.
    Of course if you do have Techstream available, that'll work too. (y)
    -Chap
    SFO likes this.
  6. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    12v battery checks out
    when Prius is turned off:
    when Prius is turned on:
    Next check tech-streamer with laptop
  7. kenoarto
    398
    Chicago, IL
    Was this after a full night's rest, never having been started?
  8. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Prii been parked for 5+ hours in this case.
  9. kenoarto
    398
    Chicago, IL
    Do it correctly this time. 10 hours not running or being charged.
  10. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
