1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Another possible lead on 2006 Nav Lockout issue...
Discussion in 'Gen 2 Prius Main Forum' started by bobr1, Feb 27, 2006.
  1. bobr1
    bobr1 New Member
    306
    Portland, Oregon, USA
    (The following applies to 2006 models with Nav)
    While doing some experimenting with the MFD today, I noticed the following:
    1. If you press and hold the "Map/Voice" button for about 10 seconds, it will beep a 2nd time.
    2. Nothing changes on the display, but it's as though it is acknowledging some next step...
    3. Continuing to hold it down indefinitely produces no further beeps.
    4. No other buttons on the MFD will produce a 2nd beep when held down.
    5. Pressing the map button on the steering wheel behaves the same way, but the 2nd beep comes after 5 seconds instead of 10.
    6. Pressing BOTH map buttons (steering wheel and MDF) results in a beep at 5 seconds and another beep at 10 seconds.
    7. I tried pressing various other buttons such as ODO and flipping the headlights on and off a few times while holding the map button, but there was no apparent change in behavior of the lockout problem.
    Any suggestions?
    - Bob R.
  2. jwe8f
    jwe8f New Member
    174
    Indiana
    Did you try changing destinations while at speed? It would be nice if one of those was the long-sought-after '06 Nav override...
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    so the Menu > Volume > tap top left, bottom left, top left, bottom left doesn't work on the '06?
  4. jwe8f
    jwe8f New Member
    174
    Indiana
    Definitely not. This is significant enough to make me happy that I have an '05... ;)
  5. V8Cobrakid
    3,790
    152
    does the Display > tap inner top left, bottom left, top L, Bottom L, T.L, B.L. work?
  6. jwe8f
    jwe8f New Member
    174
    Indiana
    You're a funny guy. Yea, that works... :rolleyes:
  7. V8Cobrakid
    3,790
    152
    lol... so are you a girl or guy? lol...
    i think the dealer should just sell the little program modules for the car.. no problems that way. I did see a recent post where some guys 06 didn't have any lockout. lol.. that would be sweet.
  8. bobr1
    bobr1 New Member
    306
    Folks ...
    The very first line in my post said: "The following applies to 2006 models with Nav"
    I don't mean to lecture, but in thread after thread on this topic, where 2006 owners are seriously trying to get some facts in order, someone comes in and immediately posts 2005 info or "you mean that doesn't work?" stuff or other useless commentary.
    PLEASE, PLEASE help us keep these threads on-topic. Thank you.
    - Bob R.
  9. bobr1
    bobr1 New Member
    306
    Yes, I tried, nothing seemed any different. I would pull into my driveway, try a few combinations of items, then go around the block and see if anything was accessible.
    Also, I tried a few combinations while at speed, but I didn't go through everything lest the neighbors think I was casing the joint...
    - Bob R.
  10. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    Thanks for the report, Bob R. Looking forward to the day when the 06 Nav override is finally uncovered. :)
  11. infohwyguy
    infohwyguy New Member
    33
    Swedesboro, New Jersey
    I'm hoping the ultimate solution for this will be found when someone is able to get the memory map for the NAV system's non-volatile memory. On another post, the menus to overwrite words in this memory was found. This would be the best and cleanest fix; overwrite the memory locations that activitate the "I agree" screen, along with disabling this bothersome greying out of certain NAV screens totally.. .and forever. With that memory map, who knows what interesting features of the NAV system could be turned on and off at will.
    Rick S
Loading...
