Another Potential Problem
Discussion in 'Gen 2 Prius Main Forum' started by The Critic, Dec 4, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
    From the blog that my independent hybrid shop posts..
    http://lusciousgarage.com/blog/
    Combo meter issues. Apparently it is becoming more common as these cars age.
    Unfortunately it appears that as time goes on, the Gen2 Prius is proving to have a number of mildly expensive issues. Add this combo meter issue to the transmission failures in the 150k range (since most have not had fluid changes), water pumps, and eventual battery issues, and this car is no longer appearing to be an economical used car choice.
    MB860 ?
    49,633
    i wonder how the percentages compare to other cars? there are plenty with no problem whatsoever.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Heh... judging by some of the OP's posts, his handle is appropriate. ;)
    Thanks for the heads up though. I should monitor their blog more often. I should've said hi to Carolyn yesterday. She was at the SF BayLeaf meeting where the Leaf's Chief Vehicle Engineer + a whole bunch of Nissan folks including some pretty senior people were present. pEEf spoke and helped organize the meeting and content.
    A few pics at http://www.mynissanleaf.com/viewtopic.php?p=155575#p155575, some more in the thread, some earlier.
  4. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    An owner who has never changed the fluid in 150,000 miles is richly deserving of a transmission failure, IMHO. Hardly an indication of an expensive and inevitable cost of long term ownership.
  5. The Critic
    3,193
    2,322
    CA
    Unfortunately most dealers in the US are afraid to change the fluid and try their hardest to convince people not to do it.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I'll just remove it myself and have it repaired if it ever goes bad. :)
    Still, $300-$400 is not bad on a 150,000+ mile car. Especially if no other parts fail. Mine has had no real repairs performed in the 151,000 miles I've driven. My seat belt is giving me issues though. :/
  7. The Critic
    3,193
    2,322
    CA
    No ICE water pump, MFD or axle seal? really?
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    My pump was replaced as part of their TSB but it never failed. MFD and everything else was either part of a TSB or just never had an issue. I think the only other TSB besides the water pump was something to do with the steering shaft but that was like 3 months after I bought it. I never had a problem but they fixed it as part of the TSB. So in a nutshell, I have never had anything fail even under warranty. Just the two TSBs which I don't consider a repair since nothing ever failed. :)
  9. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    Curious. Why would a Toyota dealer be afraid to do this?
  10. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I'm not sure they're "afraid" but many do seem to discourage it and make claims that it's "lifetime" fluid. :rolleyes: I remember hearing such claims myself when I asked to have it changed.
  11. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    There's no free lunch.
    I think that blog post is more to let customers know that they can farm out a repair of the meter (to pEEF), rather than paying full rate for a replacement.
    There are a few Prius-specific problems that will effect a small fraction of cars, like this, the axle seal, and the MFD. The OEM 12V is the most problematic component, in stark contrast to most cars. I would not characterize the transmission as being any worse than a typical car. ICE water pump has been a chronic Toyota problem across all models. But other components tend to last much longer than average, like brakes and the motor.
  12. The Critic
    3,193
    2,322
    CA
    +1, though one of my dealers did not even want to agree to do it, nor give me a price for it.
  13. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yep, there's even been a few users here that have reported the dealer refusing to even sell them the ATF to do it for them-self. Seriously! :confused:
  14. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You can have Magnusson's in Auburn do it for you. Cost is about $90. Have it done next time you're up here. :)
  15. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    It is indeed a lifetime fluid. When it fails, the life of your transmission is effectively over.
  16. JimboPalmer
    12,470
    6,869
    Greenwood MS USA
    As it leaves the factory, this is a sealed unit, no dirt can get into it.
    Once they open it up to change the fluid, you have to keep changing the fluid routinely as it is no longer sealed. For better or worse, dealers suspect owners of too short an attentions span to remember to have it done again and again at 60,000 intervals.
    The trade off is clean old fluid vs new fluid in a no longer sealed transaxle.
  17. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    I do think it is possible to get excessive moisture inside the case if left open too long. I'm glad I don't have to worry about that here. However, "clean old" is not an accurate description of used fluid out of a Prius trans.
  18. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Ours has the same policy. I've asked several times about changing the transaxle fluid and have been told that the recommendation from Toyota is not to do it.
    However now that many Gen 2s are reaching 200K and more both TM and the dealers may have much more data available to them than when these were brand new and relatively unknown in '04, '05 and '06.
    That being said I'm going to break 200,000 miles next week on a trip to FLA. Nothing has ever gone wrong with mine that I ( or another mammal ) didn't cause.
    Summary here...http://priuschat.com/forums/gen-ii-prius-main-forum/57091-200-000-mile-club-28.html#post1428250
  19. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I have had none of these issues, in fact I have not had any repair issues. I am trying to sell the car now to prepare for my new PlugInPrius. Miles: 102,000
  20. andyprius
    2,212
    188
    I changed mine at 60,000 miles, no problem at all and no expense! :cheer2::cheer2:
