Another Pre-Collision System Question
Discussion in 'Gen 3 Prius Technical Discussion' started by orfever, Oct 29, 2009.
  1. orfever
    orfever New Member
    Sacramento
    Hi-
    I'm considering buying a Prius V with the AT package in order to get the Pre-Collision System feature. But- a question- is it always on, or is on only when you turn the cruise control on?
    Thanks!
    Bert
  2. maledyris
    maledyris New Member
    77
    Burnaby, BC, Canada
    It's always on, and there's a button to disable it if you want to for some reason.
  3. priusworld
    priusworld New Member
    Los Angeles
    Bert,
    I just bought a Prius V and I just found the PCS button>Just underneath the steering column to the right>>did I see the on/off button. I asked for help with this issue and I got some helpful tips...If the "PCS" is displayed on your dash-board>>If is disabled>>OFF
    Good Luck!
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Turning it off disables automatic braking, but the other safety features are still active.
    Tom
  5. tidefan
    tidefan New Member
    Florence
    It is only on when you enable the feature. It works great and you will enjoy on trips for sure. It is turned on when you turn on the cruise control. Enjoy....Bob
  6. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Nope - it's always on. See pages 249-254 of the manual. Has 3 separate functions - (1) seatbelt retraction, (2) brake assist (applies more force when braking), and (3) auto application of brakes if collision unavoidable. As qbee42 already said, only the auto braking can be turned off.
    Seatbelts - if speed greater than 3 mph, relative speed difference between car and other car or obstacle greater than 18 mph, and someone in front wearing seatbelt (though I know it also tightens back passenger belts).
    Brake Assist - if speed greater than 18 mph, relative speed difference between car and other car or obstacle greater than 18 mph, and brakes depressed.
    Auto Braking - if speed greater than 9 mph, and relative speed difference between car and other car or obstacle greater than 18 mph.
