Another Prius 100k Maintenance Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AdamKPL, Aug 25, 2012.
  1. AdamKPL
    AdamKPL Member
    118
    East Hampton, Connecticut
    Hi everyone - been a while since I've been on the boards as lifes got in the way. Anyways, I'm the first owner of my 08 Prius and have done Mobil 1 oil and filter changes every 5k or so. Also changed the air filter a few times and aside from tires absolutely nothing else. Long story short, the Prius took a cruise to Europe and has been hanging out on this side of the pond for the last year or so.
    Currently odo reads 102k and I need to make a shopping list to purchase this stuff back in the US and ship it over here (anything related to car parts is just ridiculous here). Could you all help.
    1. Inverter/Engine Coolant - Which type/How much?
    2. Tranny Fluid - Which type/How much?
    3. Spark Plugs - Which type/How much?
    4. Transaxle Fluid - Which type/How much?
    5. Brakes - Seem ok still, good idea to buy some new pads?
    Also, just curious if you all would recommend having a real Toyota dealer do this stuff or if a regular mechanic can be trusted not to mess anything up?
    Appreciate the help in advance....
  2. Patrick Wong
    18,200
    6,479
    1. 3 US gallons of Toyota Super Long Life Coolant
    2. 4 US quarts of Toyota ATF WS
    3. 4 Denso iridium spark plugs, SK16R11
    4. This is the same as #2.
    5. Yes, you should purchase the front pads and rear shoes.
    A regular mechanic who is not trained on Toyota hybrids should not be trusted to do 1 and 5 correctly.
  3. AdamKPL
    AdamKPL Member
    118
    Cool thanks - did I miss anything?
  4. Patrick Wong
    18,200
    6,479
    If you are placing a big order, maybe you might also order a few:
    - Engine air filters
    - Engine oil filters
    - Cabin air filters
    - one PCV valve
    - one engine coolant thermostat
    - one serpentine drive belt
    - Windshield wiper refills (or blades if you don't want to install refills)
  5. gone2green
    gone2green grumpier than the grumpiest old man you know ;)
    117
    17
    Mesa AZ
    2015 Prius v wagon
    plug wires while at it would not hurt and keep the shipping charges combined
  6. Patrick Wong
    18,200
    6,479
    The Prius spark igniters sit directly on top of the spark plugs so there are no high voltage spark plug wires.
  7. gone2green
    117
    17
    Mesa AZ
    2015 Prius v wagon
    Thanks Patrick, as you can tell I have not changed my plugs yet lol
    I learn something new again thank you, very good info here.
    Is there a video of replacing the plugs on 2nd gen prius, or is it very self explanatory ?
  8. Patrick Wong
    18,200
    6,479
    I am not aware of a video. First, remove the two bolts holding the relay box mounted on the cowl above the engine and set the relay box aside, for access to the four spark igniters.
    To remove each igniter, it is necessary to remove the wiring harness connector, then remove one bolt which holds the igniter to the engine valve cover. Note that the connector has a latch that must be lifted up gently to unlock the connector.
    After each igniter is removed, inspect it for corrosion on the electrical terminals and cracking or burn marks on the plastic body. Replace the igniter if you see flaws on the plastic body as this can cause high voltage leaks.
    I moisten a clean paper towel with paint thinner, and use that to clean off the dirt/dust accumulated on top of the igniters.
    Then remove the spark plug which is located at the bottom of the spark plug well. If you see rust on the metal hex shell and porcelain insulator of the spark plug, that is an indication that water has seeped down into the spark plug well. Most likely this is because the center seam of the cowl is leaking water which drips onto the valve cover. That needs to be corrected to prevent ignition misfire.
    Replace the plugs with the correct NGK or Denso iridium spark plug as indicated in the owner's manual.
    Tightening torques:
    spark plugs: 13 ft.-lb.
    igniter bolts: 82 in.-lb.
    relay box bolts: 74 in.-lb
  9. gone2green
    117
    17
    Mesa AZ
    2015 Prius v wagon
    Thanks, I am sure others might be able to use this info too.
  10. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Moved to the maintenance sub forum.
  11. AdamKPL
    AdamKPL Member
    118
    So I just called the dealership here in Poland and they quoted the equivalent of $30 for the coolant fluid and $90 for spark plug swap (inclusive of materials) - seems too good to be true and apparently they use OEM Toyota parts/fluids. Seems like the coolant itself is like $80 on ebay.
