Another shuttlecraft
Discussion in 'Gen 2 Prius Main Forum' started by Doc Willie, Aug 4, 2007.
  1. Doc Willie
    1,717
    142
    Out there, somewhere
    Starfleet Command announces the commissioning of the second Prius-class shuttlecraft, the Zhang Sui. This follows the successful introduction of the first Prius-class shuttle, the Zhang Heng,
    [attachmentid=10363]
    which has demonstrated its superior design by becoming the most energy efficient vessel in the Federation, traveling 493 parsecs between dilithium recrystalizations.
    In the tradition of naming shuttlecraft after scientists, astronauts and TV producers, the Zhang Sui is named for a Tang Dynasty astronomer and Buddhist monk who discovered the proper motion of stars, a finding usually attributed in the West to Edmund Halley.
    It is expected that this will inaugurate a large fleet of these versatile craft.
    [attachmentid=10364]
  2. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    Back when I first got my Geo Metro, I named it The Shuttlecraft because I thought it looked like one. My housemates, however, dubbed it The Smurfmobile, the name which eventually won out.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    So is the Zhang Sui NCC-1701A/5?
    Oh and it looks really neat. I'm sure you'll be the hit of the convention!
  4. Doc Willie
    1,717
    142
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Aug 4 2007, 03:55 PM) [snapback]490593[/snapback]</div>
    Well, it would be, except that I have got the decal sets all mixed up trying to find stuff that fit. But it wouldn't be if it were not assigned to the Enterprise, The side decals now read USS Eagle, so there should be a different registration number. I'll let the Starfleet brass sort that one out. Much weider stuff has had to be explained away by the Omnipedia and Starfleet Alpha.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(Doc Willie @ Aug 4 2007, 08:13 PM) [snapback]490680[/snapback]</div>
    Doc Willie, they look fantastic. Good job changing the registration numbers. Should keep Star Fleet Command from tracing the stolen shuttles.
  6. Doc Willie
    1,717
    142
    <div class='quotetop'>QUOTE(JimN @ Aug 4 2007, 11:19 PM) [snapback]490744[/snapback]</div>
    More difficult to explain will the the 1/34 reduction in sze that occured as the Zhang Sui was transported to the surface for deployment. Fortunately, there were no personnel on board. Transporters are really unreliable for anything larger than a 20th century refrigerator (confining a wider beam is more difficult). It did, however, make it easier to steal.
  7. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  8. Starbug
    Starbug New Member
    684
    Redmond, WA
    Awwww, the Zhang Sui is adorable! Did you also give it matching underbelly LEDs like the Zhang Heng has?
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    My sweetie is a Shellback :)
