Another splash shield question with pics
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by knix6, Feb 17, 2019.
  1. knix6
    knix6 2013 4, 7/19 2011 prius 2
    46
    Oregon
    I am kind of at a loss as to which i need to buy.
    I believe i need 76851-47030 spoiler for sure as mine is completly missing.
    I dont know if i need 52618-47050 lower shield?
    I have purchased one i dont know if i need
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    #2 jzchen, Feb 17, 2019
  3. Mendel Leisk
    41,892
    Mine looks like item 19 in the first pic you posted, the ...47030.
    It goes from painted bumper, to item 19, to engine underpanel. Not sure what that other one is, have seen it mentioned before. Maybe other country?
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The one he has pictured is the same one I bought. It will bolt on and work, but it only uses every other bolt hole on the bottom of the front bumper cover. It is slightly different, but functions the same.
  5. Mendel Leisk
    41,892
    Interesting. The parts diagrams don't explain well, cause confusion. I guess there's two options, maybe for different countries.
    Our's has taken a bit of a beating: it'll push up and over concrete wheel stops, then snag/abrade/tear when you back off. I've had it off a couple of times to patch up (with fiberglass mesh and two-part epoxy) and am more careful now, don't roll all the way up to this style of wheel stop.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Also worth noting, the one he and I bought actually go inside and over the lip of the bumper cover nearly two inches, instead of merely lining up with the edge. It seems like that is an added advantage of the aftermarket piece versus OE style.
