Another steering noise (bearing wheel) and clunk
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sp00ky, Jun 15, 2020.
  1. sp00ky
    sp00ky Junior Member
    23
    Sweden
    Hello!
    I just bought a 2010 prius and everything looks OK, except for the steering where it makes a sound (some kind of bearing wheel and cluck. Car also pulls to the right on flat road. Here’s the video.
    Hopefully you guys can help me diagnose what needs to be replaced and it also makes the same sounds when i drive on bumpy roads
    Thanks!
  2. AzusaPrius
    AzusaPrius Senior Member
    2,233
    930
    Possibly the spiral cable inside the clockspring. I have heard that noise
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Normal as for pulling check all tire pressure
  4. sp00ky
    23
    Sweden
    STATUS UPDATE:
    1. All tires check, no progress.
    2. Have tighten two bolts (upper and down) on the middle intermediate steering shaft , little progress, but still issue
    3. Performed Zero Point configuration by myself via Techstream, no progress
    4. Performed Wheel alignment at non-toyota service, both front wheels pointed to the right side, right wheel was adjusted to the correct value, left wheel could be adjusted to the left since was already max. left position.
    - little progress after alignment.
    5. Performed Zero Point configuration again by myself via Techstream, seems to little bit worse than it was before alignment .
    6. I gave up :(
    I have contacted local Toyota service today and they claim at problem is 99,99% in connection between two intermediate steering shafts (45260-12710 and 45221-02050) which needs to be replaced + wheel alignment needs to be performed after change. Total cost: 780eur
    Seems a common problem, after I have described issue, he offered solution directly without any troubleshooting on the car.
    Anyone have same issue ?
    Any suggestion ?
  5. sp00ky
    23
    Sweden
    STATUS UPDATE:
    After "real" troubleshooting at Toyota, they have find at everything is OK with both intermediate steering shafts (they have change and tighten all three bolts on intermediate shafts during troubleshooting) and problem is in steering gear (45510-47050) which needs to be replaced and wheel alignment after that. Total cost: 1500eur
    Does anyone know if Prius steering gear can be repaired ?
    If not, it's ok to buy used steering gear from car with 80.000km or better to avoid used ones ?
  6. SB6
    SB6 Member
    324
    71
    Sorry, I don't know anything that would help you out. Hope someone else chimes in soon. But I noticed the video in your original post isn't working. Was it taken down?
  7. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    Did you take the video down? Any update? What was the issue? How did you solve it?
