Another steering noise/clunk
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Metaleckz, Oct 24, 2018.
  1. Metaleckz
    Metaleckz Junior Member
    23
    San Francisco
    Hello!
    I just bought a 2010 prius and it drives like a dream. Except for the steering where it makes a sound. Here’s the video.
    Hopefully you guys can help me diagnose what needs to be replaced and it also makes the same sounds when i drive on bumpy roads
    Thanks!
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Bad tie rods or intermediate shaft
    DogDaze likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,390
    3,854
    You're jerking it back and forth so fast you can't tell if the noise is because you are jerking back and forth quickly, or something else.
    Could be tie rod ends, usually that's what goes first, but a complete inspection is needed to find the bad part/parts.
  4. Metaleckz
    23
    San Francisco
    Thanks for the reply. I will try the tie rods first and see
    Edit: inner or outer tie rods?
    #4 Metaleckz, Oct 25, 2018
  5. ASRDogman
    7,390
    3,854
    Yes..... The outers wear out quicker. You can grab the tie rod and pull it and push it. It should not move.
    I've never replaced they on a Prius, but did the inners on my town and country. They are pretty easy.
  6. adonturia
    adonturia Junior Member
    españa
    The same happens in my 2010.
    Replacing the intermediate shaft is not the solution. It is necessary to replace the steering column.
    I have learned to live with this noise.
    Fostel likes this.
  7. adonturia
    españa
    Finally I found the reason for this noise:
    The cause is a washer that loosens. Many users put an additional spring, but it has not been necessary in my case. Just enlarge the wall and reinstall it.
    I can not post links yet. Send me a private message if you want more information
    Fostel, DogDaze and jack black like this.
  8. adonturia
    españa
    Look at the links in this text file. Use the chrome translator.
    jack black likes this.
  9. ASRDogman
    7,390
    3,854
    A washer doesn't loosen. Do you mean a nut, or bolt? It came loose and the washer was rattling around?
