Another Temperature Mod
Discussion in 'Gen 2 Prius Accessories & Modifications' started by JoesMorgue, Oct 8, 2008.
  1. JoesMorgue
    JoesMorgue Junior Member
    61
    Outside Detroit, MI
    I have talked to a couple of friends (electrictions) at my work, both are willing/able to help me with my work so its done RIGHT!
    Instead of a POT, and constantly adjusting, I asked them about creating an artifical floor (and a switch to let the car work normally) for the ICE temperature. One of them suggested using an Operational Amplifier (I think thats the name) a.k.a. Op. Amp to create a smaller temperature window.
    I needs to know the minimum operational temperature that allows pulse-and-glide (preferred with heat on, or both) and the voltage related to this.
    He also told me that a bunch of calculations must be done to make this artifical temperature. Has anybody done these?
    ANY help would be GREATLY appreciated, as he is not going to do all the work himself, and my knowledge of electronics and electricity is VERY limited!
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    70 deg C is about the threshold for stage 4, and there are a couple
    of charts in my ECT page. You're probably looking at about
    0.65 volts at threshold.
    _H*
  3. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    You don't have to use OP Amp to fake the temperature constantly, just use a fixed value resistor.
    You can get approx 75C(S4 area) using 360 ohm resistor parallel to the thermistor.
    http://priuschat.com/forums/prius-modifications/36342-another-thermistor-hack.html
    Ken@Japan
  4. JoesMorgue
    61
    Outside Detroit, MI
  5. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Oh, I see. You have never told us such function.
    If I were you, I'll install the attached circuit for your function, but I have not tested it yet.
    Anyway, I've never heard that Prius got over-heated.
    Ken@Japan
