Another Tire Thread
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jrb451, Aug 11, 2012.
  1. jrb451
    jrb451 Junior Member
    59
    Conway, AR
    I'm approaching 44,000 miles on the EOM Bridgestone Ecopia 100 tires that came on my 2010 Prius IV. I've been following the various tires threads in the past preparing for the day when it came time to buy new tires. While that day is still a bit away I thought I'd begin looking around to see what was available and at what price.
    I took a list of what I'd gleaned from my readings here as the top 4 tires for the Prius by my local tire dealer and all 4 are available - Bridgestone Ecopia, Michelin Energy Saver, Goodyear Assurance Fuel Max, & Continental Conti ProContact. The Michelin is by far the most expensive, $300 more than the other three.
    I'm quite pleased with the mileage I'm getting with the Bridgestone (51 - 53mpg) but the road noise is a little much. Would the Michelin's give a significantly quieter ride? And, comparable or better gas mileage? I'm trying to determine what I'd get for the extra $300.
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I don't think it would be worth the extra 300. Road nosie is part tire, but also the car. It's not like there is a 20-50% reduction of noise between tires. I'm guessing but may be wrong but i'm thinking tires would be around 1-7% difference in noise.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    How are the Energy Saver A/S tires $300 more? With the $70 rebate they are pretty competitive price wise.
    TireRack.com
    ProContact = $328
    Energy Saver A/S = $362 (after $70 rebate)
    Fuel Max = $320 (after rebate)
    Ecopia EP422 = $356
    You also have to try and compare wear ratings. I believe all of the above tires are rated similarly but the EP100 wears out faster then these 4 and the ProContact reportedly wears fast despite the 80,000 mile warranty.
    jrb451 likes this.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    jrb451 and F8L like this.
  5. PriusCamper
    PriusCamper Senior Member
    13,015
    5,289
    Pacific Northwest, USA
    So is it true that Ecopia 100 is getting discontinued? Nothing worse that driving around on a set of tires that gets discontinued... I had that experience once... It sucked! Drove around forever looking for a matching tire...
  6. priusincc
    priusincc Member
    332
    16
    NV
    I have always read good things about the Michelin Energy Saver, but they are more money. The Sam's Club price does look good though.
    My first 07 Pri came with Good Year Intregrity tires. They wore out after about 23K miles and got them replaced on warranty for a good price. The replacements were GY Assurance Fuel Max, they didn't seem to effect the mileage any, but they got noisy (whine) toward the end of life. The replacements had a 65K miles warranty, which was better than the original. However, they would have only gone about half of that mileage.
    Well, I just traded up to a 2012 Pri and it came with GY Assurance Fuel Max tires. So it looks like I'm in a vicious cycle. :( They are one size bigger than in 07, so hopefully they will get better wear.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The Energy Saver A/S is only about $40 more than the Fuel Max. You'll recoup that in gas savings because the Energy Saver is about 4% more efficient (53.8mpg vs. 51.6mpg).
  8. geeter
    geeter Member
    208
    16
    Chicago
    I just put on the new Ecopia 422 two weeks ago and drove 300 miles on them yesterday. I run them at 40 psi and I found 53 mpg for the trip. I am happy with them.
    F8L likes this.
  9. jrb451
    59
    Conway, AR
    I'm looking at these on-line and I don't see anything about a $70 rebate. Is this coupon only available at the store?
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Tire Search
    It was under Michelin generically, not just these tires.
    (for me, once it paid for mounting, balancing, tax, and recycling, my tires were $1 cheaper than list)
  11. jrb451
    59
    Conway, AR
    Any experiences with the Michelin Harmony tire? Looks like the Michelin Energy Saver is no longer available.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Tire Rack has them in stock.
    Don't get the Harmony. Get the Bridestone Ecopia EP422 or the Michelin Defender instead.
