another victim of the "too tight oil filter cap"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Maroon, Mar 18, 2013.
  1. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    So, bought my "new to me" Prius with 66k miles and now at 76k miles it's time for an oil change. I knew I didn't have the special tool for it, but having done many oil changes, how tough could it be? Well, I found out. Gentle prodding with a hammer and screwdriver didn't work so head to Advance and grab a cheapo stamped filter wrench, no go, it won't grip. Remove jackstands, lower floor jack, and put tools up while cursing the wrench monkey who over-tightned the crap out of the thing. Grabbed a beer and went inside to order the "tool" at Amazon. I'll try again this weekend.
    I know this is probably a familiar thread to the old hands here at Priuschat, but I'm new and wanted to share my frustration.
  2. DAFTEK
    DAFTEK Junior Member
    94
    Midwest
    I bought a oil vice tool from autozone that i found worked the best.
  3. gliderman
    gliderman Active Member
    751
    223
    You will break the damn thing before you can get enough rotational force to make it turn using a hammer and screwdriver.
    I am seriously thinking about getting a new filter cap($28) and filling the wrench head with epoxy and gluing the cap into filter cap wrench head. That way it will have a permanent bond and a socket and nut on the cap. The way it should be on all cars.
  4. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
  5. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    That's what I use on my Passat, but the cap is too close to the block and that kind of wrench is just too big for the job.
  6. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
  7. El Dobro
    El Dobro A Member
    7,004
    3,226
  8. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
  9. gliderman
    751
    223
  10. wjtracy
    wjtracy Senior Member
    11,335
    3,596
    Northern VA (NoVA)
    ...the biggest problem I have with DIY oil change is not being able to get the oil plug/filter off.
    When I do it myself I put them on handtight (Filter) or with socket wrench so I know I can get em off again.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    With so many of us reporting this issues from all over the country, would lead me to believe the techs are readying an incorrect torque specification from the maintenance manual...
  12. El Dobro
    El Dobro A Member
    7,004
    3,226
    I'd be surprised if they're even torquing the housing down. It's not just on the Prius they're cranking it down.
  13. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    It's all about liability. Better to hunker down on it than to leave it loose and have to buy a customer a new engine. The good thing is this is the only time I'll have this problem as I'll be using the correct specs going forward.
  14. El Dobro
    El Dobro A Member
    7,004
    3,226
    There's a spring that keeps the housing from backing off that you have to lift to unscrew.
  15. Mike500
    Mike500 Senior Member
    2,593
    764
  16. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    you can take the whole filter assembly off,only 4 bolts from the front passenger side wheel well, clamp it down with vice, use a plumbers wrench to take filter off.
  17. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I got a cheap (maybe too cheap) strap wrench and cut the strap to the most effective length to get that dang cap off. I did not want to damage the cap and the strap wrench goes a long way to making sure your hands and fingers get damaged instead of the cap. At some point I'll stop being bull headed and get the right tool.
  18. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Auto technicians that want to do the job right use torque wrenches. Technicians that want to do the job quick use whatever wrench is close (if any). Which class of technician is assigned to change oil?
  19. The Critic
    The Critic Resident Critic
    3,193
    2,323
    CA
    OP - these cartridges are notorious for sometimes being difficult to remove, even if properly tightened. Get the proper filter cap wrench from Snap-On and it will be a lot easier.
    http://image.snapon.com/international/pdf/ofwtoy3kt_npa.pdf
    Most flat-rate technicians do not get paid enough to use torque wrenches. This is unfortunate, but true. However, I would wager that most techs (or even seasoned DIYers) can have a ballpark feel for torque.
  20. Mike500
    2,593
    764
    BAH!
    Snap-On is now made in Taiwan?
    I have the Toyota one. It is still made in USA by OTC.
