Another where'd my MPG go thread...
Discussion in 'Gen 3 Prius Fuel Economy' started by billnchristy, May 12, 2011.
  1. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    My 2010 was purchased in July of 2009 and we are at just under 40k right now.
    About 800mi or so ago I had to replace the Yokohama Avid S33s that were on the car. I bought Michelin Primacy MXV4s because the Energy Savers were not in stock and my babies were bald.
    Prior to replacing the tires I had 2 tanks over 50mpg and was actually averaging around 55, this is gal/miles calculations not display.
    My commute is short and I understand I take a hit in the morning, its an 8mi hike with hills and traffic and generally sucks BUT...worst MPG in winter was around 44mpg.
    I have now had 2 tanks (one short fill) of 43mpg or less.
    When the tires were changed I took the wheel covers off, so tires and wheels were the only changes.
    It is very hard to even hit 50mpg on the highway anymore.
    I am taking it in for an oil change today, a little premature but we did note that in the past right near the 5k mark the MPGs suffered so I am hoping this and new tires are combining for bad mileage.
    I expected a 1-2mpg hit from new tires but not 7+
    Should I talk to the dealer or continue to try to suss this out?
  2. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    A little more info:
    Non-trip MPG usually around 48mpg calculated
    Winter MPG usually around 44-45mpg calculated
  3. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    Check your alignment?
  4. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    Can you have alignment issues even if the car tracks straight if you let go of the wheel?
  5. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Hey Bill, it took me a minute, but do you mean that around 5k mile intervals (not 5k on the odometer) your mileage drops?
    I'm guessing you've checked this stuff, so excuse me if it's too basic...but have you checked for any differences in tire pressure? Less likely, but oil level? Are air filters nice and clean?
  6. wstevensiv
    wstevensiv New Member
    84
    Little Rock
    and were sure its not the tires? i know they are lrr, but the bald yoko's might have been giving a good mpg because of how bald they were.
    check all that stuff mentioned and then pump up the pressure in those michelins...
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Did they rebalance your tires?
  8. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    I expected, like others have posted, a 1-2mpg hit over normal.
    My normal was 48 but I am seeing 43 or worse (Current MFD is 46.8 which is around 43-44).
    I checked pressures last night and they were 40/35 or so and bumped to 42/40.
    I agree the bald yokos were giving me that 48 to 50+ boost its just the 48 to 43 that is confounding me.
  9. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    They were supposed to.
    I have had a trip to Greenville and one to whitesburg (130 and 75 mi respectively) and have not had any shaking or anything to show them not being right....have even been up to 90mph avoiding an idiot on I-85...no shimmy or shake.
  10. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    The difference in tire size, and the new vs old tires can account for almost 3% MPG loss.
    Factoring in your shorter commute can shave another few MPG.
    Also since these tires are not LRR and you are looking at a few more MPG.
    Taking wheel covers off, maybe 0.5 - 1 mpg hit?
    I would note your MPGs on your next much longer road trip to eliminate as many variables as possible.
  11. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    If not LRR why does Michelin say they are Green X tires?
    Same tire size 195/65/15
    Same commute as when I was getting 48
  12. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    ^ My mistake if they are. I searched TireRack for LRR and they weren't on the list.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    pump em up to 45 PSI. all you can do at this point. insure good alignment, but its the tires.
  14. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    It's odd...Tirerack shows 2 sizes as LRR and Michelin shows 2 sizes are not.
    I will call Michelin and if they say they aren't then I am going to give them hell since I went for them based on that and lack of availability for the Energy Savers.
    At this point they are "only" costing me $177 a year in gas so its not worth the 600 hit to change again.
    Maybe I will try the covers back on again too. Does anyone know if you can leave the center caps on and re-fit the hubcaps?
    I know I shouldn't have changed so many variables at once, very unscientific of me but I didn't expect a hit that bad.
  15. richard schumacher
    7,663
    1,037
    United States
    The wheel covers don't make a gnat's nice person of difference. It's the tires. Inflate the fronts to the maximum shown on the sidewalls and the rears to 2 PSI less, and see what happens over a dozen tanks.
  16. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Others on here have noted that they have taken a 1-2 mpg hit when first changing out to new tires. Once the tires had a little wear they were able to regain their lost mpg.
  17. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    I didn't think so either but at this point my Fiesta isn't performing much worse so I was kinda getting desperate.
    I'll chill and see what happens. :)
  18. mikewithaprius
    656
    103
    Rhode Island
    Make sure you don't let the Fiesta beat your Prius on one of its tanks. I don't quite know what would happen, but I imagine there would be some sort of dire consequences for the entire world.
  19. billnchristy
    924
    123
    GA
    2016 Chevy Volt
    There are a couple guys on Fiesta Faction that have had 43 and 51 mpg tanks so there are some crazy non-hybrid hypermilers out there doing it already.
  20. mikewithaprius
    656
    103
    Rhode Island
    haha I know, was just kidding. ECOManiac is a Fuelly friend. 52 mpg is awesome for an ICE! He does have a dream commute...told me he drives 45-50 mph for 75 miles a day with few lights and avoids local trips. Great setup.
