Antenna base's connecting wire
Discussion in 'Gen 3 Prius Audio and Electronics' started by akio74, Jul 28, 2015.
  1. akio74
    akio74 New Member
    Oceanside
    Greetings!
    Last weekend I had the roof wrapped on my 2015 Prius. Afterwards, I noticed that the radio signal was very poor (the shop did remove the antenna base from the roof during install). Tonight I removed the antenna and wiring to inspect, and discovered one of the wires had come lose from the crimping connector.
    I've searched online, and even took it down to Fry's, however I'm not having any success in finding what this type of wire connector is called, or a replacement for it. I'm really hoping this is not a Toyota specific part.
    Pictures attached - note this is the female end, the male end if mounted in the headliner. If anyone can identify the name of the connector I need, it would be greatly appreciated!
    Thanks!
    #1 akio74, Jul 28, 2015
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    You can probably strip a bit of insulation off the broken wire and solder the connector back onto the wire.
    #2 xliderider, Jul 28, 2015
  3. mrbigh
    3,686
    699
    Long Island, NY
    the broken lead you have is a coaxial cable, it will be a TASK to do it correctly into the loose connector
  4. akio74
    akio74 New Member
    Oceanside
    @xliderider - I was initially hoping this would be a $3 connector that could be picked up at Fry's, however I'm not finding it. I like your suggestion to solder, will give it a try.
    @mrbigh - I dissected the connector and discovered the only part which broke was where the coax's core was crimped. Everything else, I believe can be put back together. I'm going to try radio shack for the connector, if they don't have it will try soldering as xliderider suggested.
  5. xliderider
    7,872
    3,116
    Honolulu, HI
    Doh, you are right... I viewed the pics on my smartphone, so I didn't notice it was a coax cable/connector.
    Akio, you may just need to recrimp the connector on the end of the coax cable. As mrbigh pointed out, coax cables aren't soldered, the plastic insulator would melt from the heat. It does look like the end of the coax cable doesn't have much of the conductor wire exposed, you might need to carefully cut away a bit of the insulator to expose a bit more before recrimping the connector on.
  6. akio74
    akio74 New Member
    Oceanside
    The crimped portion of the connector is what broke off. Here's another picture of the connector taken apart, the green highlighted area is where the crimp extended to.
    Question - can coaxial be soldered? If so, I can solider the coax's conductor wire to the metal piece which it was crimped onto, then reassemble in direction of the arrows.
    I don't have much wiring/soldering experience, does this look like it could work? Thanks
    #6 akio74, Jul 28, 2015
  7. xliderider
    7,872
    3,116
    Honolulu, HI
    Yeah, the center wire in the coax cable would be soldered onto the small connector, then reassemble, and crimp large crimp area around outer grounding wire sheath that's surrounding the coax wire.
  8. bisco
    49,511
    shouldn't the wrap place fix it for you?
  9. akio74
    akio74 New Member
    Oceanside
    Great, thanks. Will give it a shot tonight and report back.
    Probably, however since they specialize in vinyl wrap and not electrical wiring, figured I would be able to resolve myself more efficiently. If this ends up costing me more than I'd like, I may ask them to help out.
  10. bisco
    49,511
    usually they pay for you to go to a radio installer, or in your case, the dealer.
  11. mrbigh
    3,686
    699
    Long Island, NY
    seeing the exposed connector, you have a good chance of resurrecting it. Remember that you will have to crimp the shield part of the cable to the outside part of the connector.
    The worst part is the confined area you have will to work inside of the car
  12. akio74
    akio74 New Member
    Oceanside
    It's working!!! I picked up a soldering iron after work, watched a couple youtube beginner guides, and practiced on some speaker wire. I cut about 1/2 inch off the insulation, which gave me lots of the conductor wire to work with. Everything went together fine and radio reception is back to normal. Thank you everyone for the assistance!
    xliderider and bisco like this.
  13. bisco
    49,511
    congrats!
  14. xliderider
    7,872
    3,116
    Honolulu, HI
    Nice. Cheap repair, but the feeling of accomplishment = priceless! :D
  15. mrbigh
    3,686
    699
    Long Island, NY
    You learned a little bit of soldering skill.....;)
