Antenna replacement (recommendation)
Discussion in 'Gen 2 Prius Audio and Electronics' started by ericisbacchus, Jul 22, 2015.
  1. ericisbacchus
    ericisbacchus Junior Member
    91
    Kansas City
    I have terrible AM reception. I replaced the OEM one with that short Dodge one, and that helps a little. It's still not very good. Does anyone know of an antenna that will fit in there that is longer than the OEM one?
    I think the car produces some sort of field that screws with the AM reception. I've tried bringing a little transistor radio that otherwise works well inside the car -- and when inside it also functions poorly.
  2. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    It maybe the wiring from the antenna base to the head unit, or it may be the amplifier in the base of the antenna mount is defective.
  3. ericisbacchus
    91
    Kansas City
    Hmm. So switching out the antenna mount may be a good start...
  4. dolj
    dolj Senior Member
    8,633
    4,385
    If it is defective.
  5. ericisbacchus
    91
    Kansas City
    Well, what do you think I should do? Check the connection first?
