Anti Theft Alarm / Horn won't stop
Discussion in 'Gen 2 Prius Main Forum' started by Brian Yampolsky, Jul 16, 2012.
  1. Brian Yampolsky
    Brian Yampolsky New Member
    Scottsdale, Arizona
    two days ago, my horn began honking for no reason...as if the anti theft alarm was going off. I was able to shut it off only by putting the key in its ignition. Last night, the possession by the devil was complete and at 10:30pm, my car began to honk (same as before) incessantly... and I wasn't able to turn it off. This happened about 5 time within 30 minutes. I tried to disconnect the battery but of course, the Prius designers placed the battery in a location that makes it impossible to disconnect. Anyone know why this horn malfunction is occurring?
  2. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Have you ever replaced your 12v battery? If not, you should get it checked. Very possibly it's on its last legs. Since the 12v battery powers all of the computers, odd things happen when it starts to go bad.
    Also, you should check your owner's manual as to the location of the battery. It's not under the hood, and it's quite possible to disconnect it.
  3. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    It seems this is the forum's response to 80% of the problems posted. The analog to Microsoft's "reboot your computer" response.
    I can see how an intermittent connection would cause the alarm to sound, but not a low battery voltage...
    TampaPrius.com likes this.
  4. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    maestro8,
    It is reasonable for you to question the preliminary diagnosis of a weak
    12V battery.
    I dont believe that anyone here --with the possible exception of Patric
    Wong -- "sees" the connection between a low 12V battery and the
    numerous strange happenings that have been reported over the years.
    The goings on in and between the numerous computers and ECU has
    remained pretty much a mystery since the Gen I.
    There are some easily explainable non-desireable conditions that come
    from a low 12V battery. These include:
    * reduced MPGs
    * ICE running at stops even after the car is warmed up
    However, and more to the point, IIRC, all the following strange
    happenings were resolved by getting a new 12V battery. As the relationship
    is direct and one-to-one, I think they can be considered sympyoms:
    When the car is turned off:
    * the headlights come on and blink
    * the windshield wipers come on
    * the horn blows
    * the car will not start
    * and maybe the windows cycling up and down
    When the car is running:
    * the car cannot be turned off
    I sure don't "see" a connection. But that's the history.
    Let's wait and see what the OP says about the condition of the "usual
    suspect" in cases of electrical weirdness.
  5. scotthershall
    scotthershall New Member
    Greenfield, MA
    If it's not the 12v battery...
    You might have a bad door switch. If the car "thinks" the door is being opened while the alarm is armed, then it will set off the alarm. There may be alarm related swtiches on the rear hatch and hood too. I think most cars use the plunger switch on the door jam to tell if the door is open or closed, however some cars rely on microswitches inside the actual lock mechanism (VW, for one, does this). I'm not sure about the Prius.
    My 2002 VW had a bad switch on the hood. The alarm would go off randomly. Luckily with free software (VAG-COM) and an OBD-II to usb cable I was able to determine the last switch that set the alarm off. I simply unplugged the switch at the hood latch and it solved the problem. As far as I know, there's no way to tell which switch is setting off the alarm in the Prius.
    Does anyone know if there is a way to lock the Prius without arming the alarm? Could you accomplish this by manually locking the doors before closing them (and not using the key fob)? I'd go out and experiment on my car but it's getting late and I don't want to disturbe my neighbors.
    Scott
  6. Patrick Wong
    18,210
    6,513
    Check the panic button on each fob for a sticking button.
    Then, let's talk about how to disconnect the battery. There are at least two ways:
    1) Open the rear hatch, and find the 12V battery located under the right-rear hatch floor corner. Remove the negative battery cable where it bolts to the body.
    2) Find the main relay/fuse box in the engine compartment, next to the inverter. Open the box cover by pressing hard on the catch at the front of the cover, then pivoting the cover up. Find the red plastic cover over the dedicated positive jumpstart terminal and open the cover. You will see a threaded stud with a nut on it. I believe you will need a 10 mm socket to remove the nut. Then you can pull off a wire that is attached to the stud, which disconnects the positive side of the battery from the vehicle's electrical system.
    Once you know how to disconnect the battery so that a honking horn does not impair your and your neighbors' sleep, the next question is what is causing this, if you have ruled out a fob problem. It might be a low 12V battery, it might be a faulty door or hatch switch, an intermittent wiring harness connection, the body ECU might have a problem, etc. If your car has an aftermarket alarm system installed, that needs to be checked out.
    You can check 12V battery status by turning on the headlights to see how bright they appear. If dim, the battery needs to be replaced.
    If you have a digital multimeter, use that to determine battery voltage after the battery has rested overnight (which helps to dissipate any "surface charge" which inflates the battery voltage reading.) A fully charged AGM battery will measure 12.9V; a battery in OK condition will measure 12.5V or better.
    If you can't easily find a problem then I suggest you seek professional help for your car. Good luck.
    richard schumacher, Rokeby and ftl like this.
  7. Taya
    Taya New Member
    Iowa
    Hey, so I've been having the same awful issue. Last nigh it went off 20 times at 3 am.
    Tonight I tried leaving my hood open, because when I took it to Toyota they thought it was my hood latch and since I left it open, it hasn't gone off yet.
    Not sure if it's a similar issue, but I hope if it's too crazy like mine this could help.
    Good luck:)
  8. Robert Hodgson
    Robert Hodgson New Member
    Eureka, CA
    I had similar problems with 2006 Prius. Put a new battery in the fob. Didn't help. Then the panic (red) button fell off while I was diddling with the fob. That seemed to solve the problem. I appreciate the remarks that the horn blowing, light flashing was not likely the result of a a low 12V battery, or the hybrid battery. I only have 138K miles on mine and was not looking foreward to the expense of of replacing the batteries, which I am sure the local dealer would have been happt to do!
