My 2008 had a bad battery and it tripped the Anti-Theft sytem when I tried jumping it. I replaced the battery (had it disconnected for at least 30 minutes) and it either stayed in anti-theft mode or it was retripped by a weak key fob battery. I replaced the key fob battery but I still can't get it to reset the anti-theft system. I left the negative battery terminal disconnected for almost 24 hours and it still has the Anti-Theft light in the dash. What other options do I have to reset it that don't involve the TechStream app? Does it need to be disconnected for longer than 24 hours? Is it not the Anti-Theft system? Thanks in advance for any help.
Do you have the key button under your steering wheel or is there just the tire button do you have a black rubber square button on driver door and trunk? If you put the remote in the slot doesn't the red stop ?
