Antifreeze
Discussion in 'Gen 2 Prius Main Forum' started by dhoward, Sep 17, 2008.
  1. dhoward
    dhoward Junior Member
    Massachusetts
    I am coming into my second winter with my 2007 Prius. According to the manual the antifreeze used in the car is a long lasting type. I am used to draining and flushing every two years. However, I believe this is not necessary with the Prius. Is this assumption correct? If so how long do people wait before changing the coolant?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I believe it's good for 100,000 miles. It's in the owner's manual.
    Tom
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Yes and I believe it's more involved then most other cars. I've seen where there is a special procedure to bleed air out after putting new coolant in.
  4. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    It is difficult but very doable for the mechanically inclined. Weather it's needed before 100k is debatable though.
  5. qbee42
    18,058
    3,074
    Northern Michigan
    You've got that right. The bleeding procedure is a bleeding procedure (a poor play on British English). There are two coolant systems: one for the engine, one for the inverter. Both are very picky about trapped air. If you do your own coolant changes, make sure to get the service manual pages for the correct procedure.
    Along the same lines, bleeding the brake system is even harder. It takes a special Toyota service tool to activate the valves in the proper sequence. Don't even think about doing it yourself.
    Tom
  6. jelloslug
    813
    Greenville, SC
    When I bled the inverter I found an easy way to do it: I just hooked up power to the inverters coolant pump. It took about 5 minuets to fill it up completely. It was literally fill up the inverter reservoir, open the bleeder valve, turn on the pump and then keep pouring in coolant until the level in the reservoir was correct.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The Prius engine coolant bleeding procedure is not that different than a lot of modern cars. The anti-Prius (2001 Nissan Pathfinder V6 AWD), for example, was not very "user friendly". It usually took five or six warmup/cooldown cycles to get all the air out. And I had to use a home built device to do it. This after a very careful fill and bleeding procedure. Every two years for that vehicle, as it used ethylene glycol (usually dyed green). The Prius uses a version of propylene glycol (usually dyed pink), which is good for at least five years.
    For an overview of the air bleeding procedure check out the thread in the Technical section, wherein an owner was having trouble getting the air out. Posted by the below Patrick (thanks for the info Patrick).
  8. Patrick Wong
    18,200
    6,474
    Yes, the factory fill SLLC is good for 100K miles while refills are good only for 50K miles. Not sure about the reason for the difference - maybe this is because the engine coolant dry fill capacity is 9 quarts but only ~6 quarts are drained after opening the three drains.
    I recently helped another owner change both coolants on his vehicle with ~80K miles. The drained fluid looked like new, no debris, funny smells, or oil slick.
  9. dhoward
    Massachusetts
    I thank all of you very much for the info.
