Any 3rd Gen PIP owners that have reconditioned or repaired their HV battery?
Discussion in 'Gen 3 Prius Main Forum' started by priusbydefault, Jul 1, 2024 at 7:07 PM.
  1. priusbydefault
    priusbydefault Junior Member
    30
    El Monte, CA
    My 2012 PIP HV battery charge tops out at 8-8.5 miles of range according to my display. I feel like I get even lower mileage than that no matter how efficiently I try to drive.
    I am considering refurbing the battery either through reconditioning or replacing weak modules. My goal is to increase the capacity of the battery to increase my EV driving range.
    I have searched on the internet and in this forum but can't seem to find any technical data on reconditioning/replacing the lithium cells in a PIP battery pack or if it is even worth the effort.
    Has anybody taken on such a task with their PIP battery pack? I would appreciate any info or experience you could share. Or any internet site/instructional videos you could point me to. Thank you
  2. ASRDogman
    ASRDogman Senior Member
    6,048
    3,247
    You should check out the Prolong System. It's a charger/discharge to help prolong the life
    of the hybrid battery. You might be able to find a used one on ebay.
    Hybrid Automotive – Extending the Life of Your Hybrid
    There is no use in getting a used or reconditioned battery, it really won't be any better than
    the one you have now. Get a new one.
  3. priusbydefault
    30
    El Monte, CA
    I have read about the prolong charger. I have not seen anyone use it on a plug-in prius battery. I would also like to find out if it is better to do individual module vs pack reconditioning an if it is possible on this lithium pack.
    49,362
    how many miles on your car?
    i don't recall anyone ever having to recondition their pip battery.
    before attempting to recondition the battery, i would measure the battery capacity to see how much capacity is left.
    the 'guess-o-meter' is not an indicator of battery capacity, it is simply a software program that uses past performance to estimate current range possibility.
  5. priusbydefault
    30
    El Monte, CA
    The car has 166k miles. I used the dr prius app to check the life expectancy. It says it has 70% life left. I would like to prolong it's life or recover some capacity if possible.
  6. vvillovv
    vvillovv Senior Member
    3,601
    1,267
    NY
    Start leaning about Lithium Ion charging and life cycle on something smaller than the 300 lbs pack in your PIP.
    The car already has a charger included, plug it in.
