any advice or write-ups on remote start with OEM fob advice?
Discussion in 'Gen 3 Prius Audio and Electronics' started by CosbyComedy, Oct 25, 2016.
  1. CosbyComedy
    CosbyComedy Junior Member
    46
    52
    Columbus Ohio
    Having trouble finding any current info on remote start installs. Specifically DBALL with T harness from Amazon.
  2. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    Not sure which one I have but my car stereo guy put it in for next to nothing. It works with the OEM fob by clicking lock/unlock/lock with little pause between each button press. Engine turns on for the standard 15 min.
    CosbyComedy likes this.
  3. qdllc
    qdllc Senior Member
    1,370
    399
    I have a Toyota remote starter. I presume a quality aftermarket would use a similar plug-in module (basically all it is) that will start the car if a proper sequence of button presses comes from the fob (Toyota default is to double-press lock then hold lock until the system beeps several times).
  4. StarCaller
    StarCaller Senior Member
    1,244
    697
    Cedar Crest, NM, USA
    that's what I used to install my dball/
    dball.zip
  5. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    This is very interesting :)
    Does it still beep like crazy if the key is not near the car? My fob (lock/unlock) works from far away, but if I stand more than a step or two away from the driver's door it beeps like a psycho.
