Any C Owners Able to Get Car into "Stage 4" Glide?
Discussion in 'Prius c Main Forum' started by brucepmiller, Aug 22, 2012.
  1. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
  2. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    Hello, Bruce!
    I'm new at this, but like you I have only been able to maintain the "no arrows at all" state for a few seconds. I'm a whiz at the "green arrow" battery-only mode, but try as I might, and it may be due to the traffic conditions I drive in, I have yet to maintain a true glide for more than a few seconds.
    brucepmiller likes this.
  3. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Keep in mind the Mike's car is a GenII. They were much much easier to maintain a no arrows condition. The newer Prii do not work that way so none of us use the arrows display to determine if we are gliding or not. The best way to judge the ICE status is with a Scangauge or Torque app. Using the factory displays, try and keep the energy bar on the HSI display between the regen section (charge) and the EV section. I.e. try and make the bar disappear completely. When in doubt just have the bar in the first 1/4 of the EV section.
    This is what it would look like on the GenIII
    managerman, brucepmiller and jdz like this.
  4. managerman
    managerman Prius v Nerd
    228
    110
    Columbus, OH
    Having a Scangauge II in my C allows me to see the "Stage 4 Glide" very easily... the RPM hits zero and The AMP Gauge usually reads between 5.0-8.0 amp draw from the battery..In the C, the HSI shows just a sliver of green..
    -M
  5. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Aye and a proxy for warp stealth is RPM=960 or 992 and GPH=0 or .02. Or you can simply view Loop after the car has warmed up. Loop = open
  6. napmaster
    napmaster Junior Member
    50
    MA
    I made several attempts to glide today and was able to do it only once. I'm having a hard time making the EV symbol disappear even though no blue or green is showing.
  7. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I'm not sure you can reliably get rid of the symbol while gliding. It's enough if you are showing just a tiny bit of bar in the EV section. The energy use is so small that most consider it insignificant.
    secondspassed likes this.
  8. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    Max, you are sure doing something right! Very impressive MPG! In another post F8L referred to the following page for description of how the system works. Check it out: HSI
  9. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Aye, his mpg is off the hook! So is your's, Bruce.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Any arrow to or from the battery can mean anything from a very small amount of energy flow up to about 20 kw. So long as you are close to zero energy flow do not sweat the difference.
  11. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Will it actually ever disappear in a glide? I more or less assume that it just indicates that the ICE is off.
  12. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    ^That's what I thought too, considering it's on when you aren't moving at all.
  13. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    Took it on its first road trip. First half is shown below. I went the speed limit and sometimes a little less. This drive is 20 miles on flat county roads, 30 miles on hilly county roads, and the rest on a four lane. The wind must have been at my back on the way up because I only got around 53 mpg on the way home. Image 1.jpg
  14. napmaster
    50
    MA
    I was able to make it disappear one time for a couple of seconds when I was going downhill.
  15. Ashley7
    545
    222
    Oregon
    2019 Prius
    And wouldn't that indicate that the ICE came on? Or no?
  16. napmaster
    50
    MA
    It was very quiet like I was in neutral.
  17. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    I find the ICE can be pretty quiet at times, with a bit of road and wind noise it could become difficult to make out IMO. How fast were you going at the time?
  18. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
  19. napmaster
    50
    MA
    I was between the little space between CHG and EV(no blue or green) and going about 45 downhill.
