Any carista users on gen 4?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by 4thgen1st, Mar 14, 2016.
  1. 4thgen1st
    4thgen1st New Member
    Missouri
    If so are there many new features from gen 3?
  2. bwilson4web
    16,143
    Yes including:
    • P610 transaxle - entirely new design
    • fuel mixture sensor - provides significantly improved fuel mixture management
    • air inlet vanes
    • three styles of tires
    The PDF is about 220 MB. Is there some area you have an interest?
  3. 4thgen1st
    Missouri
    The only features i'm really keen on is the reverse beep and unlocking all four using one button push. I was just curious as to what else is out there. Where can I find this PDF? Thank you
    Afakan Yedi likes this.
  4. Ray72
    Ray72 New Member
    Texas City, TX
    I hope to have the 16 Four and Carista next week, and the reverse beep is first on my list. I'll let you know the results.
  5. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    I used Techstream to turn off the reverse beep (actually set to 1 beep) and disabled the seatbelt reminders.
  6. dalea
    dalea Junior Member
    Washington, USA
    Four Touring
    My dealer wanted to charge me $25 each to do both of my two Prius 4T. I decided to spend the money on the Carista purchase instead. I emailed Carista support to verify their software covered the 2016 but they said they haven't had a chance to try it yet on the new ones. I went ahead and used it anyway to change the backup beeper and also the momentary turn signal beep from 3 to 4. All work well on both cars. Only took about 15 minutes. Now I have the option to make changes in the future myself and put them back if I don't like it.
  7. vince22
    vince22 Active Member
    205
    249
    califorinia
    Forget Techstream, yes Carista app works with 2016 Prius,very easy and simple to use, just did mine a few minutes ago, here some screenshots changing reverse continuous beeps to single beep only.
    glennonrp likes this.
  8. Ray72
    Ray72 New Member
    Texas City, TX
    Received car and Carista. Using Carista, changed reverse beep and seatbelt alarms. Ordered a Techstream cable from Amazon/China. I will post my experieces with it , including gerring it to run on a Win 10/64 bit laptop.
  9. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Can Carista register a new set of TPMS sensors for a different (second) set of wheels? As in when one has a second set of wheels with snow tires on them.
    Update:
    OK, I'll answer my own question. I just received my Carista module. No Carista does not do that as far as I can tell.
  10. ucla107
    ucla107 Member
    98
    107
    Four Touring
    Here are all the options in Carista
    Doors / Windows / Remote
    Blink turn signals when locking/unlocking with remote
    *YES* / NO
    Beep when locking/unlocking with remote
    *YES* / NO
    Volume of beep when locking/unocking with remote
    OFF / 1 / 2 / 3 / 4 / 5 / *6* / MAX
    Beep when opening/closing windows with remote
    *YES* / NO
    Warn when door can't be locked with remote because it's open
    *YES* / NO
    Warn when a window is still open when locking doors
    *YES* / NO
    Warn when sunroof is still open when locking doors
    *YES* / NO
    Panic function on remote
    *ENABLED* / DISABLED
    Re-lock doors automatically if you unlock, but don't open a door
    *YES* / NO
    Re-lock doors automatically if you unlock, but don't open a door within…
    30 SECONDS / *60 SECONDS* / 120 SECONDS
    Unlock doors via remote
    *DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
    Unlock doors via physical key
    Unlock doors via smart key (door handle button)
    DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
    Auto-lock all doors
    DISABLED / *WHEN SHIFTING INTO GEAR* / WHEN VEHICLE STARTS MOVING
    Auto-unlock all doors
    DISABLED / WHEN SHIFTING INTO PARK (P) / *WHEN DRIVER'S DOOR IS OPENED*
    After locking with smart key, allow re-opening within…
    0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
    Smart key location to start car
    FRONT SEATS / *ANYWHERE IN VEHICLE*
    Open trunk via smart access button
    DISABLED / DOUBLE CLICK / *LONG PRESS*
    Open windows and sunroof by holding key in door lock
    ON / *OFF*
    Close windows and sunroof by holding key in door lock
    ON / *OFF*
    Open windows and sunroof via long-press on remote
    *ON* / OFF
    Instruments / Display / Dings
    Engine start indicator
    *ON* / OFF
    Display odometer after ignition is turned off for…
    *30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
    Reverse-gear beep
    *BEEP ONCE* / KEEP BEEPING WHILE IN REVERSE
    Seat belt warning ding (driver)
    Seat belt warning ding (front passenger)
    Turn signal click volume
    LOW / *MEDIUM* / HIGH
    Lane-change turn signal auto-flasher count
    OFF / 3 FLASHES / *4 FLASHES* / 5 FLASHES / 6 FLASHES / 7 FLASHES
    Remote low battery warning
    *ON* / OFF
    Front parking sensor range
    NARROW / *WIDE*
    Rear parking sensor range
    NARROW / *WIDE*
    Mute parking sensor when stationary for more than 3 sec.
    YES / *NO*
    Lower parking sensor beep volume when stationary for more than 3 sec.
    *DON'T CHANGE VOLUME* / 1 / 2 / 3
    Lower parking sensor beep volume when moving away from objects
    DON'T CHANGE VOLUME / *1* / 2 / 3
    Parking sensor beep volume
    1 / 2 / *3* / 4 / MAX
    Activate parking sensors in neutral (N)
    *YES* / NO
    Auto-turn off parking display when moving away from obstacles
    *YES* / NO
    Lights
    Daytime running lights
    *ON* / OFF
    Coming-home lights duration
    OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
    Auto headlights activation threshold
    DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
    Instrument lights dimming sensitivity
    Instrument lights restoring sensitivity
    Dim interior lights after…
    *7 SECONDS* / 15 SECONDS / 30 SECONDS
    Turn on interior lights when you shut off engine
    *YES* / NO
    Turn on interior lights when you unlock doors
    *YES* / NO
    Turn on interior lights when smart key in range
    *YES* / NO
    Interior footlight (bright when doors open, dim when driving)
    *YES* / NO
    Turn on interior door-handle & center console lights dimly (flood
    lights) when ignition is on and shifter is not in park (P)
    *YES* / NO
    Interior light control
    Heater & A/C
    Temperature dial calibration
    -2°C / -1°C / *NORMAL* / +1°C / +2°C
    Ambient temperature calibration
    -3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
    A/C ECO mode
    Auto-increase blower speed when front defroster is on
    *YES* / NO
    Auto-turn on A/C when AUTO button pressed (if needed)
    YES / *NO*
    Deactivate front defroster when AUTO button pressed
    *YES* / NO
    Fan speed reaches its target…
    SLOWLY / *NORMALLY* / FAST
    Patric, walterm, Rangerdavid and 8 others like this.
  11. TeachingMaroon
    TeachingMaroon New Member
    San Diego, Ca
    I'm very new to this so I apologize if my question is stupid. After I buy the Carista app, what do I do next? Do I have to tinker with anything or just go through the app?
    iPhone ?
    1stPriusLA likes this.
  12. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Thanks for the list UCLA107.
    My Carista arrived today, but I probably won't get to it for a bit.
    Most of the options are self explanatory.
    After having to listen to the parking sensor for way to long in the Dunkin's drive through line the other day, that 3-second turn off gets added first.
    I am also hoping I can adjust the distance so that they don't go off so far away from an obstacle. To my way of thinking the alarm does little good if you are still a foot away from hitting someone's bumper.
    This is the option that has me stumped. Anyone know what this is:
  13. William Redoubt
    William Redoubt Senior Member
    1,216
    1,165
    Coronado Island, California
    When you lightly use the turn signal lever but don't "click" it into position, the signal will automatically flash the specified number of times and then turn off. It's like using the signal indicator lever as a momentary contact switch.
    Mambo Dave and ATHiker like this.
  14. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    It made me laugh today when I thought about the turn signal clicking. That's now an electronic sound generated to mimic the sound of the turn signal relays that cars used to have. It would be amusing to replace that with some other sound.
    Valiant V likes this.
  15. ATHiker
    644
    560
    Massachusetts
    Four Touring
    A quack might be appropriate-- or a "honk" for those who make a distinction between a duck and a goose.
    That said, I just plugged in the Carista. Changes made easily, but can anyone tell me what is meant by "narrow" and "wide" in this context:
    *NARROW* / WIDE
    *NARROW* / WIDE​
  16. aurelio
    aurelio Member
    72
    56
    Mexico
    Good news for you. Carista beta version can do TPMS programming. Check carista website.
    SM-N900W8 ?
    TeachingMaroon, JohnF and krmcg like this.
  17. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Wonderful, that's great news! I had thought TPMS might reside in a separate, inaccessible section of the car's computer(s).
    Ducks and geese can certainly tell the difference! Behind my place is an estuary with lots of ducks and geese (Canada geese plus some domestic ones that apparently have chosen an alternative lifestyle). The geese make such a racket at night that I wish I could use Carista to shut them up! Maybe that too is in the beta version?
    #17 JohnF, Apr 5, 2016
  18. SpiniSpipi
    SpiniSpipi Junior Member
    28
    36
    Los Angeles
    Three Touring
    Ordered mine today, fingers crossed.
  19. krmcg
    2,592
    2,392
    Whittier, CA
    Ordered mine yesterday and with Amazon Prime, it was delivered last night. Installed it today and downloaded the App. Was seamlessly allowed to look at all of the available customizations and changed them at will. Worked so well - I do also recommend it.
  20. Tideland Prius
    16,528
    If I had to guess, it's the field of vision (or detection range) of the sensors. It probably means narrow angle and wide angle.
