Any cause for concern in buying new Prius sitting 4 months outside on dealer lot.
Discussion in 'Gen 3 Prius Main Forum' started by marblue, Feb 20, 2010.
  1. marblue
    marblue New Member
    16
    New York
    In a former post I referred to having to go 250 miles to the dealership in Tewksbury, Ma that has a pkg V car in SBM.
    However, this car has been sitting on this dealership's outdoor lot since November. Is it not good idea to buy a car that has been left outdoors all winter? When I heard that the car was on his lot outside it gave me pause to reconsider this purchase.
    Thanks again for listening.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    How many miles on it? I wouldn't want a car that has lots of test drive miles.
  3. hlkc
    hlkc New Member
    229
    US
    I 2nd that. If not, I don't see any problems, the longer it sits there, I bet that will be a better discount not to mention all the current Toyota problems. Make sure they get all the snow out better yet ask them to professional detail your car before deliver!
  4. Midpack
    Midpack Member
    461
    43
    Chicagoland
    I knew people here have been overhyping demand, but I had no idea things were that slow. WOW, 4 months, sounds like a Chrysler dealership. And where are those people (here) who told me I was crazy to think I'd ever get a $1000 discount off MSRP? Crickets...
  5. spinkao
    spinkao New Member
    316
    76
    Czech Republic, EU
    Depends on the price. If they give you reasonable discount, why not? Many cars never see a garage from inside in their whole lifetime, so I wouldn't be too scared because of that.
    The snow and cold water in general are not corrosive agents to be scared of; it is the salt solution from the roads which causes most damage during the winter time. So if the car just sat outside and was not driven much, I don't see a problem.
    And even if it was, I won't be afraid of it, but would use it to negotiate a favorable price :).
  6. hockeydad
    hockeydad New Member
    298
    23
    zip
    My car: "Other Hybrid"
    'Nuff said. :rolleyes:
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    While the deal as a whole sounds good, I would have concerns for the
    state of the 12v battery. We're talking a maybe $250 out of pocket
    expense.
    First off, sometimes the battery isn't even fully charged before the car
    is sold. This can lead to overly much running of the ICE and reduced
    MPGs. It also sets the owner up for a replacement before the typical 4
    year service life,
    Even if the 12v battery was good when it was put out on the back lot,
    unless they took steps to minimize or better yet eliminate the slight
    "overhead" draw that the HSD has 24/7, there is a good chance that
    the 12v has been discharged to a voltage below 12v or even 11v. In
    either case, the battery would be due for renewal, either immediately
    or again sooner than the 4 year service life.
    The problem is, it will be very difficult to get a battery reading without
    giving the dealer techs a chance to coverup any problem. Essentially,
    you have to drop by the dealer when the car hasn't been moved or
    started overnight (cold soak). With your voltmeter in hand, ask them
    to pop the hood, then take readings at the under-hood terminals.
    After an overnight cold soak, a good, strong battery should be reading
    in the 12.6-12.9v range. A reading between 12.4-12.6 is marginally
    OK. Anything lower is evidence of a seriously weakened battery.
    At the dealer, new 12v batteries go for $140-$160. Installation is
    typically ~$90 -- for 15 minutes work!
    So, how assertive you are concerning the condition of the battery
    could mean ~$140-$250 out of your pocket. Your call!
    Good luck.
  8. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I won't be too concern about the condition of the car being at outdoor for a few months. As long as the 12V battery got charged up to full capacity, it should be good. However, I'd be more concern why this car has been with the dealer for so long because Pruis should be a hot seller, especially before the recall issue came up after January. If the discount is very very significant, otherwise, I wouldn't take the chance.
  9. putty
    putty Member
    147
    39
    somewhere in the swamps of Jersey
    look for scratches
  10. marblue
    marblue New Member
    16
    New York
    Thank you for pointing out potential battery problem. This is a new car that has maybe 3 miles on it. The manager told me today that they only move their cars when it snows so they can plow their lot. Other than that it hasn't been driven or moved. However, it will be going through a service check before it sold, especially the brake software fix.
    But, if I understand you correctly, that you can't get a accurate reading of the strength of the battery if it was started up recently. Then the read out would appear to be okay? Unfortunately, I can't just drop over to do the cold car battery check given the distance away. This leads me to ask, aren't the batteries covered in the warranty when you buy a new car?
    I understand the potential problem now and thank you for pointing it out. By the way I am getting almost a $2k reduction in price compared to the MSRP price in I was getting in NYC.
  11. duffasaurus
    duffasaurus Senior Member
    177
    38
    Charlotte, NC
    I would try to get invoice for the car since it has been sitting there for 4 months. I am sure the dealer is desperate to get rid of it, considering all the interest he is paying each month. I was able to get invoice on my 2010 V/atp in January before the recall crisis!
  12. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Unfortunately, these are the exact conditions under which the 12v
    battery could be inadvertantly over discharged. This isn't a for sure
    thing. It's just that given the generally low understanding about
    Prius operating specifics at most dealerships, it can happen despite
    their best uninformed and misguided efforts. -- it has to do with
    whether or not the 12v battery is "on the line" in each of the three
    Power button positions.
    OK, but unless you really push hard, it is unlikely that they wiil even
    look at the battery, after all, it's brand new. How could there be a
    problem?
    Also, you might ask that they do a "load test" on the battery. Tell
    them you want to see the "ticket" or "ribbon" from the test. Even if
    you end up buying a new battery from the dealer, you should tell
    them a day or two before you buyit that you will be doing so, and
    please ensure that it is fully charged for pick up. Tell them you will
    want to get the ticket/ribbon, dated on the pickup date.
    Hope this helps.
  13. marblue
    marblue New Member
    16
    New York
    Prius V's don't really sell much. They are somewhat expensive for a Toyota. The IV's are in much greater demand and are far more readily available. Just a very few of the V's are allocated to a particular region from the research I have done. In addition, in Northern Ma. there probably isn't much demand for a Prius V like there maybe in a metropolitan area.
    Nevertheless, I am getting an almost $2k reduction in price off the MSRP.
  14. mike lipke
    mike lipke New Member
    89
    MN
    Don't overthink this. It is a new car.
    Worst case is a new battery someday: 175 dollars.
    Under warranty for couple years anyway.
    They sit on the ship for weeks, no one cares.
    Get the best deal you can and buy the thing. You will love it.
  15. marblue
    marblue New Member
    16
    New York
    Yes, perspective on this is a good thing. And knowing some of the potential
    problems just makes me a bit smarter in getting a good deal.
    Thank You.
  16. fuzzy1
    10,167
    I'll agree with the sentiments to not overthink it, just use it for a bit of leverage in negotiation.
    My Honda had a dead battery on the lot, an interior light had been left on, and it needed a jump to allow a test drive. In the end, it lasted the same 8-ish years I get from others in my very-battery-friendly climate. Your climate won't allow that life even on a fresh battery.
    The part I should have reamed them for was not disclosing, until delivery paperwork was being signed, that the car was already several weeks into the 12 month / 12kmile warranty. It had been sold previously, and warranty started, but something (financing?) collapsed. (The odo was still in the low double digits.) But in the end that didn't matter either, as I ran the warranty out on miles, not the calendar.
    Then I kept it another 22 years.
  17. F512M
    F512M Member
    415
    Laguna
    I would ask for good discount. If not go for a newer car.
  18. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    These are my thoughts also. I would look to see if it was wrecked and repaired for instance and would not want it it it was.
  19. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    There should also be a Maintenance mode on the NAV screen that can be used to check 12v battery voltage. Easier to plug in a ScanGauge. Still easier to ask the dealer to check & print for you. Since the brake ECU is being flashed the 12v battery is going to be charged up for 40 minutes. You should get 3 readings.
    Look at the voltage readings BEFORE you buy the car. If they are low insist that the 12v battery be swapped out BEFORE you buy the car. I'm sure even a weak battery will be fine for the short term & won't strand you on the way home. However, if (when) that battery fails the replacement will have a 1 year warranty.
    Get the VIN & check up on the car at
    Toyota Owners Online | Official Toyota Owners Website
    Hope everything works out for you.
  20. marblue
    marblue New Member
    16
    New York
    Perhaps you don't know that this car is at Ira Toyota of Tewksbury, a bonafide Toyota new car dealership. They are selling this car as a new car with 3 miles on it. I believe it hasn't sold because there just
    isn't enough demand for Prius V's in general and especially in that area. And that's why they are very hard to find. They are just not allocated like the popular Prius IV's with the solar roof package.
    Aside from the battery issue which is an understandable result of sitting on a dealerships lot, I find it hard to believe that it is anything but a new car. But perhaps you weren't aware that it is at a reputable Toyota dealership. Sorry for the misunderstanding.
