Any Comments from Dealers on your EV?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ScubaX, Dec 9, 2005.
  1. ScubaX
    ScubaX Member
    484
    Redding, CA
    Has anyone with an EV installed had any comments from their dealer's services department? Do they just mind their own business? Have you had any work done under warranty with the EV installed?
    Just wondering now that some time has gone by with these mods installed and I have not heard of any warranty denials or threats of it.
  2. samkusnetz
    samkusnetz New Member
    85
    Portland, OR
    i'm also curious about the relationship between installing an EV switch (in the USA) and the warranty...
  3. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Dealer had no comments on my EV button. They did make me remove the can view for the big code update. It interfered with the car going into "sleep mode". Also they removed my radiator block, but made no comment, just put the carpet inside the car.
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    No mention about my EV switch when I was in for the recall. After all they installed the EV mod.
  5. Tideland Prius
    16,157
    nope. I'm using Coastal's so it's hidden
  6. aaf709
    3,862
    2022 Prius Prime
    I don't have one (at least yet), but I feel that it will be rare for it to cause a problem with warranty. First there'd have to be a battery problem and then the service tech would have to know about the mod. After that they'd have to put two and two together. Unless there's a sign in the shop that says, "If you see this modification, the battery warranty is void!" I don't see a problem.
    Now, if a particular dealer wants to put the blame on a problem on the mod simply because they couldn't find the real problem, that's another matter.
  7. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    techs at the dealership here are more curious than anything. i don't think they really care.
    you could just cover the button up with some electrical tape and they probably wouldn't notice it. they're not out searching for these things to be able to point a finger, they're just there to fix the car. unless the button is directly in their way or they have to do something with the dimmer switch right next to it, chances are it will go unnoticed.
    but, every place is different- as we have seen in the varied service reports in this forum alone.
  8. ScubaX
    ScubaX Member
    484
    Redding, CA
    They installed the EV mod for you? Which one did you get, the Coastal Tech or the Toyota stock switch?
  9. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Yeah, SeaSalsa, I was thinking the same thing.
    My EV has arrived but I haven't put it in yet. If I need to take the car in for work, I'm hoping I can uninstall the mod - or perhaps just the button - just in case.
    By "just the button" I mean that if they need to take the dash apart, I would remove the whole thing. But if they are not going to take the dash apart, I would consider popping the plug back in place and just tucking the mod inside to hide for a little while. By the way, can I do that?
  10. Don-RI
    Don-RI Member
    153
    Cumberland, RI
    Can you provide details - did you order parts (what, from where). What was the dealer's cost to you of the install? Any issues at all? Thanks.
  11. seasalsa
    1,278
    Kent, WA
    Don-RI, TonyPSchaefer,
    Actually they installed both! I had a stock switch that I got from Japan as well as the Coastal mod. It was all in an envelope along with instructions. The Toyota Tech. who did it had done several of both types. When he noticed both mods he came looking for me to see which I wanted. I had gone down the street for a cup of coffee so he just decided to install both. He quoted 1.5 hours labor which included a road test with me, it came to $127.50.
    One comment on Warranty work. Dealers love it and will fight to get it done under warranty. I have never had any warranty work turned down by a dealer, if it is really extensive they have to get approval from Toyota. Most warranty work is a moneymaker for them. The latest recall was quoted at 3.5 hours and in most cases took much less.
  12. samkusnetz
    85
    Portland, OR
    interesting.
    the manager at my dealer here in portland, oregon suggested that i not install the ev mod. he said he wasn't sure of anything, but "it sounds like that would interfere with the warranty."
    huh.
  13. seasalsa
    1,278
    Kent, WA
    Don't see how it could really be much of a warranty issue since it is standard everywhere but North America. They didn't include it here because EPA couldn't figure out how to rate a car with this feature.
  14. tomdeimos
    995
    Lexington, MA
    Why don't you ask the dealer what mods you can install? I've never seen a dealer give permission to do anything to a car that they don't supply themselves.
  15. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Why do you need both?
  16. IFixEm
    IFixEm New Member
    69
    a gallon south of Microsoft
    He did not need both, but as he said, I was not sure whitch of the 2 he wanted, and since he was not here to ask I installed them both and charged him for one. Seemed like the right thing to do.
    Every dealer has a bit of wiggle room as to what is or is not warranty. You have to ballance customer satisfaction and repeat business (& referals) with what is the root cause. Regionally there are lots of tacomas around here. Someone goes down the steet and gets a suspension lift. Now the angle of the front cv boots are excessive. The boots poped off because of the angle. We call the customer and tell them their lift caused the problem not the boot. We recomend appropriate modifications to prevent it, and then warranty the boot one time. That is the ballance we try to find.
    The only way I think anyone will get into trouble with an EV is if you bend a terminal on the ecu somehow, or damage the connector getting a pin in 27. The ECU would be hard to get thru warranty, no problem on a connector.
    Regards, Mike
  17. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I was just wondering why he would buy another one if he already had one.
  18. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    My dealer didn't say anything. Probably didn't notice. After all, that red button could be anything. They never had to get behind the dash, so there's nothing to question about a wire going from one end of the dash to the other tapped into the ECU.
    Only problem I could see is if the ECU has to be replaced. I snapped the release tab to the connector that holds the connector to the ECU so it is more difficult to remove the plug. Didn't take much force to snap it either. Them plugs are HARD to pull out.
  19. seasalsa
    1,278
    Kent, WA
    My son-in-law makes frequent trips to Japan and picked up the factory switch for me while I was waiting for the Coastal Mod. (they have a history of long delivery times) That’s how I ended up with both. Both work without conflict and I can chose which to use depending on conditions.
