Any contact for the Prius shop on here?
Discussion in 'PriusChat Website Questions' started by TSonn, Oct 24, 2020.
  1. TSonn
    TSonn Junior Member
    Michigan
    I purchased a rear bumper protector at the beginning of the year and it's starting to peel which causes the hatch door to not open properly. I'd really not like to purchase another one since the protector is still basically new but no one has responded to my requests using the "contact us" form on the shop.
    Anyone know where I can find the adhesive strips used to stick the protector to the bumper?
    Or if anyone from the shop is on these boards - is there a way I can just buy the adhesive strips?
    Thanks in advance!
    49,500
    since it's a kit, they probably won't have anything. is it double sided tape? have you loked around on amazon?
    maybe you can just glue it back down
  3. TSonn
    TSonn Junior Member
    Michigan
    Appreciate the response!
    I've tried double-sided tape and glue but there seems to be too much torque pulling at it (it's only coming up from one corner) that those two things can't keep it down. I think I have to redo the adhesive for the whole protector.
  4. fuzzy1
    10,172
    The website owner, @Danny, is also the PriusChat Shop contact. However, the past couple years, his attention has mostly been focused elsewhere.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Go to an auto parts store and look for 3M double sided mounting tape.
    If that won't hold it, likely nothing will.
    I suppose you are adverse to putting a couple of sheet metal screws in it to "help" the tape ?
