Any deficiencies compared to "regular" Prius?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by NewHybridOwner, Aug 20, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I'm trying to talk some family members out of buying an early-2000s Subaru Forester (there were significant numbers of major engine problems) and have suggested they consider a Prius V, as they make frequent long trips to visit family and want something economical.
    But does the Prius V suffer from any problems of its own that would not be found in a regular Prius?
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Other than worse fuel economy, I don't know of any.
    bostonbruins8703 likes this.
  3. NewHybridOwner
    607
    283
    W. Michigan
    What kind of fuel economy should they expect in a Prius V? (Or better: how much worse compared to a "regular" Prius?)
  4. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
  5. bisco
    51,155
    but they didn't make a v in the early 2,000's
    knockknock_2 likes this.
  6. NewHybridOwner
    607
    283
    W. Michigan
    Sorry! I should have written "early 201x".
    They had seen a 2010 Forester that they liked -- but now I hear that any Prius model is out for them because they don't want anything in which they sit that close to the ground.
  7. bisco
    51,155
    you're probably better off. if they bought an early gen 3 and got the blown head gasket, they might blame you
  8. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    I don't believe a v has any major flaw differences as compared to a standard Prius.
    I'd look to model years 2015 -17 as the latest and greatest.
    Fuel economy expect 40 overall.
    Rear seats recline.
    Storage/ luggage capacity is superior.
    Driver comfort is good.
    Softex fabric wells well.
    Models 1,2,3 with 3 offering LED headlights & fog lights, BOSE stereo and sunroof as I recall.
    2 is a good deal and for the comfort/ options so I'd skip the 1.
    If I was to point out weakness I'd say:
    Brake maintenance (which maybe the same as a reg. Prius) requiring maintenance/ inspection/ lubing of the pins more than a usual car plus a brake pad change seem to have a special procedure over a regular car.
    The v is a box in cross winds.
    Rear wheel alignment can be difficult.
    I notice you live in Michigan.
    Not sure of a v in a snow zone, so a 4 wheel drive may be an important consideration for you.
    Yet, the v is still a good car.
    Good luck in your decision.
  9. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I suspect it gets 10 MPG less than a Gen 3 liftback.
    Top speed is 103 vs 115. I find it hard to believe this is an issue.
  10. bostonbruins8703
    bostonbruins8703 Active Member
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    I find the MPG will vary depending on location and driving style. I frequently hit over 45-55 mpg throughout most of the year in New England. The V is 5.7 inches. Which the standard Prius is 5.5. The ground clearance isn't an issue for me and I've yet to get stuck in snow. I've driven through over 6 inches of snow and through blizzards and I haven't had any issues on my all season tires. I've driven on 1400 mile road trips, packed with luggage and driven around with 5 people in the car with no complaints about discomfort. Getting in and out both the front and back is easy for passengers and the driver; especially for the elderly. Ultimately, its a good car that you can't go wrong with if you pick the V. Sitting in a standard Prius compared to the V, you just can't compare the extra room you have with the V. I've transported so many large items in mine including; a 44 gallon water heater, plywood, a door with a screen door attached to a door frame, a queen size mattress in the back.
  11. Mendel Leisk
    40,584
    Rear brakes on the v incorporate a mini-drum brake, for parking brake function. If anything, that might be a plus: the regular Prius rear brakes have some gotcha's. Not deal-breakers, but you have to be on your toes.
    Prius v Repair Manual is one I haven't managed to cadge so far, btw.
