Any downside to removing the wheel covers on the LE except for MPG?
Discussion in 'Gen 5 Prius Main Forum' started by TgrXtrm, Mar 31, 2023.
  1. TgrXtrm
    TgrXtrm New Member
    22
    Ohio
    2023 Prius
    Basically title, looking at this post I found on FB I think this looks great. Thinking about doing the same to my reservoir blue when it comes in next week sometime.
    49,371
    none that i can think of, and you probably won't be able to measure mpg loss either
    TGrracie and TgrXtrm like this.
  3. TgrXtrm
    TgrXtrm New Member
    22
    Ohio
    2023 Prius
    Hope you're right but I wonder what the purpose of them from Toyotas perspective is then. I wouldn't imagine they'd add something for the sake of it.
    49,371
    i'm sure there's a tiny mpg hit. when you're building high mpg cars, you have to look at everything and quantify it.
    TGrracie, Trollbait and John321 like this.
  5. Trollbait
    11,505
    You might get more wheel noise at higher speeds without them.
  6. Mendel Leisk
    38,646
    Get the centre caps. Hopefully they’re available…
    TGrracie likes this.
  7. Hammersmith
    Hammersmith Senior Member
    1,305
    1,331
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Probably
    42603-52170 - Chrome logo and outer ring on a gloss black background. 62mm diameter (2 7/16")
    also 42603-06150, 42603-08010, 42603-06160, etc.
    or
    42603-12780 - Black on black. 57mm(2 1/4")
    #7 Hammersmith, Mar 31, 2023
    TGrracie and Mendel Leisk like this.
  8. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    On the 3rd generation, I think the covers were supposed to be worth roughly 1% of aerodynamic drag. However, they add 3½ pounds, about 0.1%, to overall vehicle mass.
  9. Maxwell61
    Maxwell61 Active Member
    384
    238
    Italy
    Please, can someone skilled with editing color in silver the alloy wheels?
    Thanks a lot!
  10. hill
    8,153
    Like this?
    Any small loss of MPG due do wheel cover removal can easily be offset by bumping up tire pressures 4 or 5Lbs or so. Higher pressures also reduce the likelyhood of hydroplaning in rainy weather
    #10 hill, Apr 1, 2023
    Maxwell61 likes this.
  11. Mendel Leisk
    38,646
    In a nutshell, you want to see the rims in silver?
  12. Maxwell61
    384
    238
    Italy
    Thanks, but i was talking of painting the rims in silver :)
    Yes!
    And would also be interesting to see the aerocovers in silver.
    Both rims and covers in black just makes me puck on any car :confused:
  13. hill
    8,153
    Chrome would look really nice also but it's environmental issues seem to have taken it out of vogue. But spraying them isn't such a bad idea because if/when you get a curb rash, using off-the-shelf spray paint colors for touch up repair is often 10X cheaper than what the auto manufacturers charges for their OEM spray touchup.
    #13 hill, Apr 2, 2023
    TGrracie and Maxwell61 like this.
  14. GuyLR
    GuyLR Junior Member
    30
    24
    Atlanta, GA
    Lots of wheels refurbishing businesses out there who can blast the black off and re powder coat with just about anything you can imagine.
  15. Maxwell61
    384
    238
    Italy
    Better to have a Photoshop first :) but nobody seems interested to gives us a try :(
  16. JGC61
    JGC61 Active Member
    214
    101
    Long Island
    I had the dealer leave the hubcaps in the original package and I purchased center caps.
    This is my forth prius.
  17. mrlarrys
    mrlarrys Junior Member
    25
    68
    PA
    2023 Prius
    the caps are ugly and light weight, are a pain to get back on after being removed get one side on and the other pops out while at the same time - you are afraid of cracking them. (I put on the toyota prius mud guards) but not much else available right now for options. And I dont know if the mud guards help - they are very small but easy to install.
    Alessandro_Ibi likes this.
  18. tahufive4
    tahufive4 Junior Member
    2023 Prius
    Do you have a copy of the instructions to install the mud guards by any chance? I'm curious if you had to drill any new holes into the car.
  19. C313
    C313 New Member
    2023 Prius
    I honestly like the look of the base rim without the cover.
    One thing I don't like though is the hole in the center with the cover off.
    Is there a specific size for the center cap? I have an LE coming once out of allocation and I'm likely gonna take the cover off and sell them. But would only do so with a center cap
  20. Hammersmith
    1,305
    1,331
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Looks like yes. One new hole for each front wheel, and three holes for each rear wheel.
    This is the official installation guide for the European Prius Prime, but it should be the same for a regular Prius:
    https://www.toyota-tech.eu/aimuploads/9bf6f40d-908f-4937-8c63-771df8e1ab9d/Prius-Plug-in_Mudflaps_PK389_47R00_P1_AIM_005_290_0.pdf
    tahufive4 likes this.
