Any guides on inner CV boot replacement?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SB6, Dec 14, 2019.
  1. SB6
    SB6 Member
    324
    71
    So my right CV axle came loose while replacing my lower control arm. We got it back in, but a bunch of grease came out. It was recommended here that I get a CV boot kit rather than what I thought would be just a regreasing.
    I got an OEM boot kit, but since I've never done this before, I was wondering if there was a guide on doing it. I see there's a 1A Auto video on replacing the entire axle, but I'm just replacing the boot.
    #1 SB6, Dec 14, 2019
    The Critic likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    From the 2010 Service Manual.
  3. SB6
    SB6 Member
    324
    71
    Dang, looks like it calls for a transmission fluid drain? Was hoping it was a simpler job
  4. Mendel Leisk
    41,856
    The transaxle fluid drain/fill will be a walk-in-the-park compared to the rest of it, lol.
  5. ChapmanF
    18,492
    It's a 2010, you probably wanted new transmission fluid anyway. :)
    Raytheeagle and Mendel Leisk like this.
  6. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    If the only problem is that grease came out, I would just pump some more grease in there and be done. Pretty simple to do that.
    Doing a boot replacement is much more involved, which is why due to low skill or high hourly rates, combined with ultra cheap, low quality replacement axles, the more common solution is to do an axle replacement (the axle + both CV joints/boots, all new or rebuilt, replaced as a single assembly).
    tankyuong likes this.
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    SB6, Raytheeagle and Mendel Leisk like this.
  8. SB6
    SB6 Member
    324
    71
    How would I tell if my current boot/clamp etc are fine (other than checking for tears in the boot)? If I could verify that, I could just regrease. I borrowed a grease gun from a friend to use on the grease fitting on my new ball joint. I'm guessing that won't work here? I didn't notice a grease fitting when I tried looking around the CV boot.
    Also, in the transmission fluid drain video I saw, they mentioned replacing the transfer case gaskets. If I'm "draining" by removing the CV axle, would I still need those gaskets?
  9. frodoz737
    4,719
    2,517
    33
    Here is another ref to reboot/grease CV axle inner and outers. CV Boot Repair As for the drain and fill on the transmission, there are many, many posts/threads here about that...and a lot of stupid "discussions" about whether it should be changed at all...but we're not going there today. Since it has leaked already though...here is everything you need from said SM...including the axle/case seals if needed.
    SB6 likes this.
  10. SB6
    SB6 Member
    324
    71
    Thanks! I just watched the video and saw that he didn't do anything with the transmission fluid. Looking at the repair manual though, I'm guessing we have to on the prius
  11. The Critic
    3,193
    2,333
    CA
    Just have a pan under the trans before you remove the axle. Top off as needed.
    iPhone ? Pro
  12. Mendel Leisk
    41,856
    A clue in this transaxle fluid change picture:
    The level of fluid will be roughly at the centre of the drive shaft (larger circle, just to the right), so a minor amount will drain out at most.
  13. SB6
    SB6 Member
    324
    71
    I decided to just do the drain, so I've ordered Toyota transmission fluid, a pump, and 2 gaskets. However, I ordered 4 quarts and now I see that it calls for 5 quarts. I probably shouldn't do a "partial drain" right? I can just run to the dealership and grab my 5th quart I guess
    frodoz737 likes this.
  14. frodoz737
    4,719
    2,517
    33
  15. 2012 Prius v wagon 3
    281
    278
    Not sure what car you have or where you saw 5 quarts, but my 2012 Prius v took 3.7 quarts.
    And just in case ... you need Toyota ATF-WS, not anything else.
    Have you figured out what happened with the CV grease, and what damage may have been done due to the intial problem? If the boots are in good shape, you really don't need to go through the boot replacement process, or the axle removal, etc. Sometimes less is more.
    #15 2012 Prius v wagon 3, Dec 16, 2019
    SB6 likes this.
  16. Mendel Leisk
    41,856
    That sounds about right. No need for a fifth quart. (y)
    SB6 likes this.
  17. SB6
    SB6 Member
    324
    71
    I was looking at NutzAboutBolts's transmission drain and refill video, and in the description he lists 5 quarts of transmission fluid. But you're right, it looks like I should only need a little under 4 quarts.
    I actually meant to do that today, but looks like I forgot . I'm planning to check on it tomorrow though.
    If I don't see any damage and therefore just need to apply grease, what would the process be to do that? Since I don't remember seeing a grease fitting, I'm assuming I can't use the grease gun I borrowed
  18. Mendel Leisk
    41,856
    I think you'd need to follow the steps in @The Critic 's video. Or a new one.
  19. The Critic
    3,193
    2,333
    CA
    The clamp will always require replacement. Replacing the inner cv boot is not that difficult. The trickiest part is removing the tripod from the shaft. Either use a brass punch or a 3-jaw puller with a socket as the spacer. You must use the special cv boot pliers to reinstall the new clamp though.
    iPhone ? Pro
    frodoz737 and Mendel Leisk like this.
