Any idea how I can resolve this these two rust spots
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by heyphillip, Nov 3, 2018.
  1. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    Just brought this 2010 Prius 2 with 103,400 miles for $8,000 vehicle in excellent shape except two small rust spots. Not surprised at this considering where the vehicle was purchased new and driven most of the cars life. Upstate New York which have brutal winters with road salt 20181102_160115.jpeg 20181102_160054.jpeg
  2. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Are you near Lansing? You might check with Keith Armstrong.
  3. tvpierce
    tvpierce Senior Member
    951
    881
    Maine
    2013 Prius v wagon
    I assume you want to do this DIY?
    If you're finicky about paint, you're not going to like how this goes. First off, remove the black cover in the second photo. It looks like there's more rust under there. You need to scrape off the bubbles with a scraper, sand the rust off, etch the metal, and seal it. Then cover with touch up paint that matches the body color. It's not going to be perfect, but it will look decent, will protect the metal and keep the rust from spreading.
    I recommend the POR-15 Starter Kit.
    If you want it to be perfect, take it to a body shop and they'll do a professional job. You'll pay for it, but you'll not be able to tell that it was ever there.
    Personally, I'd DIY it. But that's just me.
    Good luck!
  4. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Unfortunately that appears to be coming from beneath rather than a break in the paint surface. Probably more will follow in time.
    Since this is not exclusive to the Prius, I suggest you review Utube. With moderate you'll keep it looking good.
  5. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Grinding, sending, rust proofing, filling, sanding, prime-ing, painting
  6. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    New Jersey
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    With an 8 year old car that has 103K miles.....that kind of goes with the territory and trying to "fix" it might be a mistake.
    The little brown spots on the flat panel probably just need to be kept polished and waxed.
    The ones showing signs of "bubbling" could be scraped a little and some touch up paint added.
    Personally I think that would be a waste of time.
  8. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    I'm like you trying to repair it might make it worst. I spent 2 hours bar claying and waxing the car. You could tell who ever had it didn't really wax it personally. Kind of strange that this car even has this problem.Ive never heard of a Prius from 1st Gen to Present ever having rust issues. They hold up pretty well
  9. bisco
    51,155
    Agreed. My daughters 2008 has never been washed or waxed,, yet looks like new, albeit a bit grimy at times. Maybe it protects the paint:p
    Raytheeagle likes this.
