Any Idea What This Connector Does?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hal.9000, Jan 20, 2025.
  1. Hal.9000
    Hal.9000 New Member
    2009 Prius. This connector is behind the windshield washer fluid reservoir and left of the brake fluid level sensor. The wires are severed at both ends. I can't find much reference to it. The only thing I could find is (maybe) a diagram that calls it S2 and S3 "Short Connector".
  2. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
  3. Hal.9000
    Hal.9000 New Member
    That would probably explain why I have a code regarding the brake master stroke simulator. Now I just need to find where the other 2 wires are that I need to connect back together. Thank you!
  4. Tombukt2
    Tombukt2 Senior Member
    12,032
    2,127
    Durham NC
    What you would do here is go to a junk car sitting at a tow lot and cut that connector off with wires coming out of it aplenty if you will put some butt connectors or however you do your joinery from the wiring that you just cut with the plug to your car which is severed by animals or whatever should be no problem You do need the connection to be there if you don't have a junkyard and you can't get to it I may have one here so on and so forth whatever it takes
  5. pasadena_commut
    pasadena_commut Senior Member
    2,220
    661
    Southern California
    What do the brakes feel like on this car?
