Any idea why the aux in doesn't work when you use a lightning splitter (charger and audio)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by SDB54, Sep 2, 2019.
  1. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    I have a lightning splitter for my iPhone that has both a charger and audio connection on it. Basically a lightning Y cable. It works fine on my 2007 CR-V, but when I try it on the Prius, the audio doesn't work.
    I've since tried the just a lightning to 3.5mm audio cable plugged into the the aux in, and that works great.
    Sure would be nice to figure it out since Apple gakked the headphone jack from newer iphones : (
  2. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    As far as I am aware, the "Plug Present" detection is just a mechanical switch in the jack. Compare the physical plugs of the cable that works with the one that doesn't and see if there is a difference between them. My only other idea would be to try a short extension cable (Male -> Female 3.5 mm) and see if that works.
  3. fuzzy1
    10,460
    Does the phone audio work with a regular, non-splitter cable?
  4. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    It's odd, but the same cable that doesn't work with the splitter works on it's own when plugged into a female 3.5mm to lightning cable.
    I tried another splitter from a different manufacturer and it works. Not sure what the difference is..?
  5. Leadfoot J. McCoalroller
    8,090
    7,570
    Pennsylvania
    2018 Prius c
    Mechanical fit? sometimes you just can’t get a given cable to land the last click.
