Any interest in adj illuminated s/w buttons??
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BT Tech, Jan 14, 2006.
  1. BT Tech
    BT Tech New Member
    885
    South Florida
    Since day one the very dim steering wheel buttons have bothered me so I am now in the process of making that a distant memory.
    There are several ways to go about "fixing" this issue but I wanted to see if there was sufficient interest in coming up with a marketable product.
    What I had in mind was to simply use the existing illumination control to vary the brightness of the switches on the S/W. The same way that it controls the dash lighting and the MFD.
    Before I start to get into this I wanted to see how many of you would actually be interested in this kind of product.
    The cost of this product would probably be under 100 dollars but this could change depending upon the quantity produced.
    Any feedback or suggestions would be appreciated!!
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  2. kpauley
    kpauley New Member
    149
    Gilroy, California
    Seems there are several people discussing this issue in a more current thread, so maybe there is interest. I think it would be nice if it adjusted with the dimming wheel....not sure how much I'd pay though...
    Dimm steering wheel thread
  3. saechaka
    saechaka Member
    225
    count me in for one as long as it's under $100.
  4. tbstout2
    tbstout2 Member
    156
    Hallieford, VA
    Brian,
    I'd be interested as well. One thing I'd like to add, though, the turn signals and high-beam indicator lights are not regulated by the dimming switch - and I think they should be. The reflection of these lights, when in use, bug the heck out of me.
    BTW, love the stiffening plate!
  5. jwe8f
    jwe8f New Member
    174
    Indiana
    I'd love it too, but it would have to be reasonably simple to install and way under the $100 suggested above. Would you have to exceed the operating range of the lamps in the steering wheel?
  6. sseres
    sseres New Member
    37
    I'm here to second the request for "way under the $100." Maybe something in line with coastaltech's ev mod ($45)? Love the idea, though!
  7. DocToss
    DocToss Junior Member
    69
    Cordova, TN
    I am interested also, for the right price.
  8. comtech5
    comtech5 New Member
    35
    Southampton, NY
    I am interested...the overly dim buttons are a major flaw in my opinion. Would love to see an aftermarket solution!
  9. habel
    habel New Member
    230
    Oslo, Norway
    Same here - for the right price (way under 100...)
  10. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    I would be interested as well as long as it's 1) an easy intsall and 2) less then a hundred
  11. craigcush
    craigcush Member
    157
    Sedona, Az
    From radio electricians point of view, I would be concerned about exceed the operating range of the lamps as well. Plus the cost stated.
    Those lamps were chosen for their output by design. to exceed that would dramatically reduce life of the bulbs if not fry them in a few hours to days depending on their rating and voltage applied. (or resistance removed)
    I am all for it. But not if I have to pull it all apart later in the year to replace all the bulbs.
    Perhaps the parts catalog specifies voltage and I am wrong, hope so. Real problem finding the buttons for me.
    Were you going to make a harness to reroute the source voltage through the dimmer?
    Thanks for stepping up to resolve, I wish you the best.
  12. BT Tech
    BT Tech New Member
    885
    South Florida
    Okay everyone.. I will keep you all up to date on my progress on this new mod.
    My intentions are to keep this looking stock and to have the curent illuminator adjust the brightness on the S/W buttons so we can actually see them at night.
    I wish I could talk to the original designer or who was responsible for the current design and drag him out back!!! :angry:
    I will try to keep the price as low as possible.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  13. coolfire74
    coolfire74 New Member
    47
    Boston, MA
    I want one if under $100. Thanks!
  14. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    I definitely want that modification. Please do it and $100 is fine with me. But, if you really wanted to get the market captured, take over where Coastal Tech has apparently dropped the ball. Make a navigation/blue tooth modification to solve that problem. I have waited for 3/4 of a year and still nothing from Coastal Tech yet.
    Thanks, Michael (Cairo94507)
  15. BMcGraw
    BMcGraw Member
    230
    Southern California
    Put me on the list too Brian. And while you're at it, an Audio/Video interface controllable via the steering controls would be nice. Just Coastal's ViewTech2010...but one that's really on the market! :angry:
  16. dbarry
    dbarry Member
    114
    Houston Texas
    Count me in!
  17. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    I've Got a Spare 2006 Prius Steering Wheel For You
    Brian,
    I have a 2006 Prius steering wheel that I'll donate to the cause. It's complete with all standard and navigation buttons, so you can experiment all you want with out risking damage to your own Prius or buying any parts. I doubt you'll be able to talk to the original designer, but you'll at least be able to take one of his designs apart.
    Add this to your research; it sure seems like the illumination on the 06 leather steering wheel buttons is brighter than on the standard 06 steering wheel I'm offering you. Maybe there's a Toyota modification you can use as a model.
    Good luck and I hope your mod will adjust off the dashboard dimmer switch and not damage the light source.
  18. cgraham
    cgraham Member
    156
    33
    New Mexico
    Please keep me informed
    I only got my Pri yesterday and have not evaluated this issue yet.
    I agree no use overloading the existing bulbs.
    C
  19. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Guess you mostly want responses from the "I want it" group...but here's one from the "no thanks" group.
    First of all after about 2 months with the car you can find, by feel, all the controls. They all have a distinctive location and tactile pattern on them making them accessible day or night without removing your eyes from the road.
    When it is extremely dark finding the buttons by sight is no problem, for me, at all at the current brightness levels.
    I guess, if it were really cheap and easy to install (<$25 and <15 minutes) I might get the mod just to maintain my reputation as the fearless guinea pig of Priuschat. And there are, I admit, times where it would be nice if they lights were a little brighter, but I too am concerened about the impact of using a dimmer and life of the bulbs.
  20. BT Tech
    BT Tech New Member
    885
    South Florida
    Thanks Vincent and this is very gracious of you!! I will let you know if this is needed but at present I am all set. I had to use my own as the "guinea pig" as I started this project some time ago.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
