Any issues with EV driving with the Low Fuel Light for a long period?
Discussion in 'Prime Main Forum (2017-2022)' started by noonm, Nov 4, 2019.
  1. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Finely had the 'low fuel light' turn on for my current tank of gas. However, as my regular driving involves almost exclusively 100% EV driving, I can feasibly continue driving for weeks (or months) without having the refuel.
    My question is:
    • Presuming the engine never turns on, is there any risk to me continuing to drive in 100% EV mode with the 'low fuel light' on?
    51,669
    nope
    just don't get caught needing to go along way and no time for gas
    but you probably still have 2 gallons in there
    Rmay635703, Tha_Ape and jerrymildred like this.
  3. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    I would say Toyota is very cautious with its fuel gauges; even though on a few occasions I drove 8-10 miles past the "0 miles" warning, I have never been able to cram more than 8.3 gallons of gas into what I believe to be a 9.5-gallon tank ... the way I drive this translates into "0" being something like 75 miles worth of range.
    That said, I wouldn't push my luck any further than I have.
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    You are reducing the choices the computer has to protect your car. You have to ask yourself, Why?
    kenoarto and MTN like this.
  5. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    I believe that the low fuel light turns on when you have 30-50 miles of reported distance to empty on gasoline. Once your distance to empty reaches 0, you still have 1 gallon of gasoline left. I usually reset my trip B and I know that I will run out of gasoline when trip B and the trip B fuel economy are the same number. Make sure you have electricity left, and switch to EV only mode when you run out of gasoline.
    I have run mine out of fuel 3 times, and I used the electricity that I held in reserve to arrive at the Costco gas station that was my intended destination. I only drive long distance and it is critical that I know exactly what I can and cannot do. When the Prime runs out of fuel, it goes into a mode where it appears very under powered until you switch to EV mode. Once you switch to EV mode, it drives normally.
    Once you put fuel back in it, it just acts normally like nothing happened.
    When you finally run a Prime out of fuel, you should be able to put 11 gallons in it. The rated capacity of the tank is 11.3 gallons.
    Dimitrij likes this.
  6. schja01
    schja01 Senior Member
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    Generally it’s a better idea to keep the tank full. Less condensation especially in winter. At least that was the recommendation.
  7. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    When you let the fuel get that low you are actually causing the fuel pump to suck air. That's a sure fire way to shorten the life of your fuel pump which is not an inexpensive part.
    kenoarto and mikey_t like this.
  8. Salamander_King
    Salamander_King Senior Member
    11,013
    8,942
    New England
    Don't think so. As @bisco said, the low fuel light on means there is still ~1.7gal in your tank. Conservative HV driving will give you at least 90 more miles of range.
    But do you really want to keep staring at the low fuel light every day?
  9. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I recently drove about ~70 miles at ~70 MPH on the low fuel light, 100% ICE.....
    Rob43
    fuzzy1 and bisco like this.
  10. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    You must have a very high tolerance for anxiety! A steady yellow light on the dash would drive me nuts. Of course, I'm a former military pilot, so warning lights really bother me.
  11. bisco
    51,669
    nothing like real world testing (y)
  12. bisco
    51,669
    i fill up to 3 gallons, and refuel when the light comes on. i have read that condensation isn't a problem in these sealed systems?(n)
  13. Trollbait
    12,461
    Presumably, you'll get the big warning message when the car actually runs out of fuel, so I see no risk with just having a the low fuel light on.
    However, colder weather will be here soon, and that means shorter EV range with the ICE more likely to come on for heat and defrosting.
    Because of emission regulations, gas tanks are now far better sealed than in the past. Besides, the ethanol will remove any water that manages to get in.;)
  14. VTBIGDOG
    211
    146
    I don't dispute what you're saying about the low fuel light coming on. The previous poster stated that he lets it run out of fuel which is a totally different situation
    kenoarto likes this.
  15. Salamander_King
    11,013
    8,942
    New England
    Yeah, I know what you mean. My response was directed to OP not to your comment. Sorry for the confusion.;)
  16. frodoz737
    frodoz737 Top Wrench
    4,664
    2,490
    33
    This infatuation with and/or justification of running on or near empty escapes me.
  17. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    It could be worse, one year we had a poster enraged he was not rewarded for running out of gas routinely.
  18. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Don't get me wrong, I understand the sentiment, but I have a particular reason to push the limit....
    The Race for 500mpg!
    I know its a bit of a fiction, as its not the true "mpg for a single drive", but because its on my dashboard, I really want it to read 500mpg before I fill the tank.
    Trollbait, Salamander_King and bisco like this.
  19. bisco
    51,669
    and i want a pic (y)
    and, oh yeah, i'd be all over that
  20. Salamander_King
    11,013
    8,942
    New England
    To reach 500mpg at the current use of gas, you would need to drive to 4602miles.
    That would be only 317 miles more.
    At 30 miles EV per charge/day, you only need 11 more days.
    Go for it.
    jerrymildred likes this.
