Any issues with gas getting old in the tank
Discussion in 'Prime Fuel Economy & EV Range' started by tsT, Jul 20, 2017.
  1. tsT
    tsT New Member
    NorCal
    I'm sure people have discussed this ... I'm curious to know what research or information is out there about gas getting old from sitting in the fuel tank for extended periods of time due to primarily using the electric motor.
    Anyone read anything about this? Any discussions you can point me towards? Thanks!
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes, time limits are built in to make the car burn the gasoline by forced running of the engine (ICE) if one drives too long in EV only. For example, my CMax Energi requires at least one tank per year be used. The gas tanks are pressure sealed more than other vehicles to help keep oxygenation low which, in part, makes fuel go bad. Between the two, the driver should have no worries about gasoline condition.
    phlack and Trollbait like this.
    52,383
    welcome!
    there is another thread on this, and some debate over whether the engine will exercise itself every so many miles.
    some owners claim thousands of ev miles without the ice firing. the o/m will tell you whether or not you have to use up the gas in the tank, and either way, you can always add fuel stabilizer.
  4. tsT
    tsT New Member
    NorCal
    Thanks for the responses. I couldn't find the other thread, but found a little bit more info by reading around. Thanks!
    Prius from Dad likes this.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    is it the "ICE comes on anyway" thread @bisco?
  6. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    bisco and priuscatprimeguy like this.
  7. priuscatprimeguy
    2,730
    2,640
    Arctic_White, bisco and joachimz like this.
