Any luck slowing oil burning with a stop leak (lucas, blue devil, bars, etc.)
Discussion in 'Gen 2 Prius Main Forum' started by MilkyWay, Mar 28, 2019.
  1. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    That is a different product than the photo in post 29. So your saying it did help with your oil consumption? That’s good. Perhaps another round will help even more, keep us posted.
  2. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    I believe it worked and was a noticeable difference. I'm maybe 1 or 2 days from taking my @ 3000 miles picture but I know it will be pretty low. But, before, I think at 2k miles I'd be where I'm at now --- at 3k miles --- if that makes sense.
    That pic was a mistake --- that is what we used to fix a lifter noise on a BMW.
    The Prius Mechanic I know said he has reduced oil consumption by using Nano Pro MT. Problem is he said he uses it at every oil change and it costs $25/bottle so I'll stick to the $12/bottle stuff right now.
  3. a_gray_prius
    2,927
    783
    IL
    Why are you putting Royal Purple in a Prius?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Why NOT ????
  5. MilkyWay
    823
    359
    23
    MI
    Was using Mobil One full synthetic from 140k when I got it and up....Started burning after 40k miles of me owning it (around 180k). So now I consider Mobil One FS a gimmick/junk!
    It is very cheap at Walmart (about $30 for oil/filter).
    I went to Walmart and the highest-priced oil was Royal Purple @ $37 or so...
    With the Liqui Moli and Royal Purple it seems to run really good. Starts off purplish when you look at dipstick and then turns light gold. It is nice and makes engine run smooth thus far.
  6. a_gray_prius
    2,927
    783
    IL
    With the rebate (that's been going on for like 5 years already), it's like $13 for the 5qt jug. Add the $5 OEM filter+drain plug gasket and you're talking $18 total.
  7. MilkyWay
    823
    359
    23
    MI
    Thanks for tip! I have mobil one promotions bookmarked but haven't checked recently. That is a great deal but doesn't serve a purpose for my use right now. Will think about it though cause price so low!
    Mobil 1 Rebates at Participating Retailers | Mobil™
  8. MilkyWay
    823
    359
    23
    MI
    @ 3k miles
  9. Mendel Leisk
    41,400
    You've gotta give the camera nothing else to focus on, lol.
  10. BurkPhoto@aol.com
    56
    High Point, North Carolina
    My ‘09 built and bought in 2008 has 181,200 miles. It burns about a quart between oil changes. Still gets the same mileage as when brand new.
    — Bill Burkholder
  11. oil_burner
    oil_burner Active Member
    249
    126
    I'm starting to think synthetics don't make much of a difference. My car was burning a lot of oil as well, 275k and it had synthetics all its life. When oil consumption started getting worst I tried a few things in the oil like MMO, Seafoam in the spark plug holes, etc. I pulled the valve cover off that engine a few days ago and it was nearly spotless, the cleanest I have ever seen with no sludge at all. So there was no lack of detergents in the oil, I believe its just a case of poor ring design with this engine.
    MilkyWay likes this.
  12. Skibob
    2,912
    1,502
    Northern California
    I can see it fine. Just zoom in.
  13. MilkyWay
    823
    359
    23
    MI
    Skibob likes this.
  14. mehullica
    mehullica Junior Member
    39
    United States
    Have you replaced the PCV valve? Try a high mileage engine oil after changing the PCV valve
  15. MilkyWay
    823
    359
    23
    MI
    Done in past on previous gen 3 prius and does/did absolutely nothing. I did change PCV valve on this car when I got it at 140k miles.
    I'm using the most expensive oil I can find (Royal Purple). It is almost 2X more expensive than Mobil One at Walmart.
  16. sam spade 2
    7,035
    2,801
    2017 Prius c
    Sorry but that doesn't make any sense to me.
    You are losing oil fast.......so you put in more expensive oil.....blindly, without knowing if it is supposed to help reduce the usage or not.
    IT IS NOT. And you are blowing more money out the tail pipe.
    You need to try an oil that is designed for "high mileage" vehicles, of a slightly thicker viscosity that what was recommended when it was new.
  17. MilkyWay
    823
    359
    23
    MI
    Not blindly....I'd more say experimenting and whaddya know it worked as expected! With the oil stabilizer + purple oil it is a slightly thicker viscosity.
    Before @ 2k miles the oil change shop said I was 2.5 quarts low...
    And whaddya know here I am round 2 of experiment @ 2k miles today and still full..
    There are only 2 options at Walmart. The Mobil One JUNK that I have used for years very faithfully.
    Been using it from 140k to about 180 or 185k when I noticed severe oil consumption.
    The only other option at Walmart is Royal Purple which happens to be a very expensive oil which would indicate to me that it is a good brand. Which is why I went with it.
    I crossed 210k miles this week.
    #57 MilkyWay, May 11, 2019
  18. MilkyWay
    823
    359
    23
    MI
    Round 2 @ 2k miles still pretty close to full and before I was 2 quarts down.
    On round 3 I'll just update @ 2.5k and 3k cause that is when it starts to burn using this oil concoction. Before I'd be burning after 1k miles.
  19. sam spade 2
    7,035
    2,801
    2017 Prius c
    And the expensive oil likely had NOTHING to do with it working better.
    But you are welcome to believe whatever you want.
  20. MilkyWay
    823
    359
    23
    MI
    Unfortunately nobody will ever know.
    Because, unfortunately, I am not a scientist with a 1 million dollar grant to take 30 different 200k mile Priuses that all burn the exact same amount of oil and then try 30 different concoctions to try to determine with a degree of certainty that 1 oil concoction works better than another.
    Typically the most expensive product is the best product and as stated Mobil Junk was ruled out cause issue started with Mobil Junk. That left only 1 other option at Walmart.
    After running these 2 products a couple more times I'll switch to a different oil and see if burning gets worse.
