any one can help me .....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mohad, Oct 6, 2013.
  1. mohad
    mohad New Member
    Amman, Jordan
    hallo ........
    I sent my car to the mechanic, and after I returned the car and found that he may change the
    Inverter by another one
    The car does not work well now.
    Is it possible to know if it has been tampered with my car via the vehicle's computer.
    And how?
    I think hi is Specialist and may be he reset the computer to accept the new one
    my car prius 2010
  2. mohad
    mohad New Member
    Amman, Jordan
    hallo ........
    any one can help me
    And how?
    my car prius 2010
  3. matt b.
    matt b. Member
    251
    60
    L.A.
    did you take it to Toyota to have the work done? I didn't think, bad move to save a few dollars not everyone can work on a Prius, now you may know why.you probably need to do what you should have done in the first place take the car to Toyota have them diagnose it.
    51,140
    the inverter is expensive. how much did he charge you in american dollars?
  5. mohad
    mohad New Member
    Amman, Jordan
    in about 3000$
  6. mohad
    mohad New Member
    Amman, Jordan
    hallo ........
    Is it possible to know if it has been tampered with my car via the vehicle's computer , or special tester .
    And how?
    my car prius 2010
  7. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    As mentioned a number of times, take it to an authorized Toyota dealer.
  8. bisco
    51,140
    $3,000. is very likely the inverter. sounds like he messed something up. did he replace the inverter coolant pump as well? also, the inverter warranty is 3/36 i believe.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I am so confused:confused:
    SAMSUNG-SGH-I747 ? 2
  10. bisco
    51,140
    he took his car to the mechanic for repair and 3k later, something is wrong.:eek:
