any one having problems with engine clatter on cold startuo
Discussion in 'Gen 2 Prius Technical Discussion' started by cobra427, May 27, 2012.
  1. cobra427
    cobra427 New Member
    australia
    just thought id throw it out there i have a 2006/2007 prius that on cold start up works its self up to a rattle/ vibration in p mode on charge
    49,434
    no, and i don't recall seeing any other threads on it either. how many miles? how long have you owned her? when did it start?
  3. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    I know it's an old post, but to answer the question, yes it's normal. On cold mornings I've had a rough start-up and it goes away after the engine is warmed up.
    49,434
    still might be helpful to him, at least he's not alone.:)
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    With this type of issue it's often worth looking into exactly what type of engine oil you're using. Sometimes changing the brand/type of oil will ease the problem.
