Any one install Parrot CK3000 bluetooth to 2007?
Discussion in 'Gen 2 Prius Technical Discussion' started by GreenEarth, Apr 1, 2007.
  1. GreenEarth
    GreenEarth New Member
    Has anyone installed the Parrot CK3000 to a 2007 Prius? I just purchased a 2007 touring edition without blue tooth :>(
    Or, is there a better system to install? I would like the system to integrated into the stero system so that it can use the Prius speakers.
    Open to suggestions, thanks
    Greg
  2. beboyle
    beboyle Junior Member
    39
    Phoenix
    <div class='quotetop'>QUOTE(GreenEarth @ Apr 1 2007, 02:22 PM) [snapback]416110[/snapback]</div>
    I just finished installation of the Parrot CK3000 Evolution in my 2007 Prius with standard (non-JBL) stereo. Install was easy with the Toyota harness from Parrotkits- just plugged in connectors, no splicing. It works fine, mutes the stereo, plays through the speakers even when the stereo is off.
  3. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    I stuck a Parrot CK3200 LS in my 97 Tacoma and it is awesome! Excellant sound quality and performance. It also automatically syncs with my Cingular/ATT&T cell (Motorola Razor) each time I start the engine. That way the phone book is always updated! The installtion should be the same for all Toyotas once you have the proper install harness.
