Any one know where 12vdc power outlet fuse is?
Discussion in 'Prime Technical Discussion' started by Dael, Sep 30, 2021.
  1. Dael
    Dael Member
    128
    32
    Ohio
    2020 Prius Prime
    Found it, It is close to wall by brake lever, (third fuse location) Power outlet # 1!
    can't delete thread....?
    #1 Dael, Sep 30, 2021
  2. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    Hey Dael. I posted this earlier without having seen this thread:
    Interior Fuse Box. P/OUTLET 1 and 3. No 2. | PriusChat
    Do you know how I might test if it's still "P/OUTLET NO.1" on my PP? Do I just remove the fuse then try plugging something into the 12v DC outlet?
    Dael likes this.
  3. Dael
    Dael Member
    128
    32
    Ohio
    2020 Prius Prime
    Check points on fuse for voltage? "white" dots on fuse top, either side of ' "15" ' are contact points. If you replace fuse and try outlet?
    Darien Day likes this.
