Any other cars with the same 15-in. wheels?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Mar 12, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    When I had snow tires fitted on our 2015 Prius Four, I just had them install them on the original wheels, but I'd like to have the all -season tires put back on those wheels and get a set of identical wheels, if possible, on which to have the snow tires installed ready for next winter. None of the junk yards around here have Prii of any year at the moment, so I am wondering if any other cars that might be more readily available use the same wheels.
  2. Mendel Leisk
    38,728
    I went with this, when getting snow tires for our 2010. In the fall of 2010 the rims were $70 apiece, and the 20 nuts $31 in total:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
    As a makeshift centre cap, to cover the hub (it rusts VERY readily if left exposed), I used a 2" ABS end cap. They have an inside diameter of 2.375", which is slightly loose, but I found if I cut a rubber band out of an old bicycle inner tube, and pushed it over the rim's hub opening lip (carefully), and then tapped the cap on, it stays put.
    The lug nuts you could likely improve on, either using the stock (which will stick out, look a little odd), or some acorn style if you can find. They all seem to be about 38~40 mm long though, one-size-fits-all I guess. I find the open-ended ones are ok, except:
    1. They don't have a shoulder at the base, so you want to be careful putting a socket on, to avoid chewing the paint of the rim.
    2. The stud tip is exposed, rust prone. I've adapted by brushing a drop of oil on each one, once or twice during the winter.
    They're not purdy, just functional:
    I have a set of Plug-In Prius rims waiting in the wings, will likely swap them when this set of tires wears down a bit more.
    #2 Mendel Leisk, Mar 12, 2019
  3. Mendel Leisk
    38,728
  4. NewHybridOwner
    607
    282
    W. Michigan
    I was thinking that if I could find a set of identical wheels from, say, a Corolla, complete with the TPMS sensors (my local yards sell "wheel and tire sets," which presumably include the TPMS sensors; are they going to bother removing them?), I could use those for the snow tires next winter and not have to bother with new nuts and center cap.
  5. PosauneGuy
    PosauneGuy Member
    117
    88
    California, here I come...
    Since you don't need them till next winter, be patient and peruse the For Sale forum here and auto salvage yards. I have two Prii, each with their own set of snows. For my 2011, I picked up rims from someone who was selling here on Priuschat (I think I paid about $200 for the rims and $100 for shipping) and for my 2015, I found a set from a salvage lot about 100 miles from home (paid $275 for the rims).
  6. Mendel Leisk
    38,728
    Look before you leap with the sensors. Maybe you need them to pass inspection in your state. Tirerack has a list of what states require that. If not, consider the "snow tires with sensors" dilemma: you will need to "introduce" tpms sensors to the car, twice yearly. A dealership will charge maybe $75~90 for this, tire places less.
    If you're DIY'ing the tire swap, that's a bit of a pain. You can buy equipment to do it yourself too I think.
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    By the way, 5 bolt, 100 mm pattern, 15 inch rim
  8. NewHybridOwner
    607
    282
    W. Michigan
    What I did with our Pontiac Vibe was bought just a set of basic steel wheels at the local tire store (part of a small regional chain) and provided my own TPMS sensors (bought on Amazon). They put the all-weather tires back on the original wheels and put the winter tires (which I had bought at Costco, not at that tire store) and the new TPMS sensors on the steelies. They switch the wheel/tire combos for me and reset the TPMS system each season at no charge. So I might be better off to do the same again for the Prius.
