Any owner with bluetooth but no navigation?
Discussion in 'Gen 2 Prius Main Forum' started by shah, Jan 14, 2010.
  1. shah
    shah Love My Prius
    43
    Houston, TX
    Sorry for the unusual request. I just bought a used Prius that has bluetooth but no navigation. HOwever I see a Map button on the steering wheel. I don't have any map related buttons on the dash board. I was wondering if this is normal. Or my steering wheel has been changed and it actually came from the car that had navigation. Remember I have bluetooth and it is working and hence I have the bluetooth handsfree and the phone pickup and hangup buttons right underneath the Map/Info buttons on the steering wheel. Also the Info button works and switches the display between the mpg screen and the engine view screen. It is just the Map button that does not respond of course since it does not have the Navigation. When I press it it says there is no external device present.
    So I was wondering if there is anyone out there who owns a Prius with bluetooth but no navigation, and still has the Map button on the steering wheel.
    Any feedback will be appreciated.
    Thanks.
  2. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    No, even the non-nav cars have the map button. Press it and the MFD will read that the equipment is not installed. Pearl is probably the same package as yours, though they were slightly different in the two years. Everything but nav.
  3. shah
    shah Love My Prius
    43
    Houston, TX
    Thanks for the info. That's what I was hoping. Cleared my doubts. Thanks again.
  4. ncmm87507
    ncmm87507 Junior Member
    37
    Beaumont, Ca
    My wifes car has bluetooth and no nav. and the map button is there also.
  5. neilz
    neilz Member
    134
    Staten Island, NY
    My 2010 has BT and no nav. I don't have a map button.
  6. shah
    shah Love My Prius
    43
    Houston, TX
    Thank you guys for the responses. This cleared my doubts.
    @Neilz: I have a 2009 Prius - Generation 2. It is quite different from the Generation 3 2010. Sorry for not mentioning it in the original post.
  7. macmaster05
    macmaster05 Senor Member
    4,050
    729
    No. The base model does not have the map button.
  8. GeekEV
    GeekEV Member
    417
    NorCal, USA
    My 2006 pkg 6 has bt, no nav and the map button.
  9. tdhammonds
    tdhammonds New Member
    Jonesville, VA
    Is there an external device you can instal to have navigation if you have map button, but no navigation?
  10. Politburo
    Politburo Active Member
    971
    208
  11. Pattyforprius
    Pattyforprius New Member
  12. Pattyforprius
    Hello, I have the same issue with my prius. It is a 2006. It was a hand me down from my parents. When I got in it I set up the phone and then went to the nav and just like you. I have nav on the steering wheel but nothing on the dash. Luckily I had the original paperwork and it did not come with nav, got my parents on the phone and confirmed that there were no accidents. Maybe toyota was just cheap and did not make a steering wheel without the map option.
