Any Pixel 8 Pro Users?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by scotched, Jan 12, 2025.
  1. scotched
    scotched Member
    76
    108
    Encino, CA
    2023 Prius
    I'm just wondering what your experience has been with Wireless Android Auto so far.
    Mine seamlessly boots up with the car maybe 20% of the time. Otherwise, I find myself waiting with a blank screen for minutes OR having to manually connect via the screen.
    Maybe there are some dev settings I could change?
  2. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    I get the same issue also having to go into the multimedia screen every time I start the car after it's sat awhile...it forgets my Android S23+ about 60% of the time. I do frequent updates to Android Auto...on 13.5 version now....any thoughts to fix this?
  3. scotched
    scotched Member
    76
    108
    Encino, CA
    2023 Prius
    I haven't found a solid "fix" yet. There are some BT settings in developer mode that play with the quality of the wireless connection but not the handshake between the phone and car. AA has always been janky. I wonder if carplay has these issues and it's just the OS and NOT the car.
  4. Agronomy
    Agronomy New Member
    2024 Prius
    XLE AWD-e
    I have a pixel 8 pro and sometimes is automatically connects sometimes it doesnt. Ive just begun connecting via wire because of it and the fact that it would sometimes timeout while driving and I would lose my route on waze while driving and have to reload it all. The worst of it was when I drove through areas with no signal and couldnt reload my route at all cause my phone had no signal to download the data again. total pain in the nice person.
    Oh well, its not like the wireless charger works anyways, the wireless experience in this new prius was shit to begin with
    scotched likes this.
  5. scotched
    scotched Member
    76
    108
    Encino, CA
    2023 Prius
    @Agronomy
    I've lost connection randomy at times, but it usually picks back up. I find a bit of comfort is knowing it's not just me.
  6. Paul Gregory
    Paul Gregory Senior Member
    2,264
    604
    Alberta
    2024 Prius Prime
    XSE
    My Gen 5 connects to my Samsung Galaxy S23 most of the time. When it doesn't, I reboot the phone, and reconnect.
    I had assumed the wireless connection was Bluetooth, but apparently it's using wi-fi.
  7. Paul Gregory
    2,264
    604
    Alberta
    2024 Prius Prime
    XSE
    I can tell you that it won't connect if you're using a VPN.
  8. PhoS
    PhoS Active Member
    257
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    It would fail to re-establish android auto 10% of the time on my Pixel 8 pro. It seems to be a little more consistent on my 9. I still get one every now and then where nothing works and both the phone and the radio need to be restarted.
  9. Paul Gregory
    2,264
    604
    Alberta
    2024 Prius Prime
    XSE
    Surprising that it would fail more often than a Samsung product, considering that both Android Auto and the Pixel phone are made by the same company.
  10. sheltem
    sheltem Junior Member
    2024 Prius Prime
    SE
    Wireless CarPlay has been flawless on my iPhone 16 Pro.
  11. soft_r
    soft_r Active Member
    191
    160
    Beverly Hills
    2024 Prius
    For anyone who may come across android auto issues, in developer mode if you have set your animations to 0x it will cause problems with android auto. You need at least 0.5x animation speeds. There are 3 speed settings, don't know which is the culprit because I didn't feel like fine grain testing, this is an obscure issue because no one messes with this stuff normally and I think I only ever found one other person talking about it on reddit.
