Any reason heated seats shouldn't be left on indefinitely?
Discussion in 'Gen 3 Prius Main Forum' started by Pugsy, Nov 13, 2009.
  1. Pugsy
    Pugsy New Member
    76
    I've taken to leaving my heated seat on for the cold months since it's a pain to bend down to turn it on and off. Does anyone know of any reason why I shouldn't be doing that?
    thanks
  2. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I would only think that it would result in additional battery drain which may cause the ICE to run more often. That would be a concern, and since your in CALIFORNIA, is it something you really think you would want on all the time in the "cooler" months?
  3. Pugsy
    Pugsy New Member
    76
    Alright, so it isn't BUFFALO, but it does get below freezing around my neck of the woods. :)
    Thanks for the reply.
  4. bob brown
    bob brown Member
    114
    17
    South Florida
    Too bad the seat heaters don't have timers and/or thermostats that would automatically turn them off when car interior reaches a certain tempurature, similar to the heated rear window.
  5. Tideland Prius
    16,532
    I don't see why not. It cycles so it's not like it's continuously on and it doesn't get so hot that you have to manually turn it on and off (like our '02 Camry).
  6. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    Turned mine one about 3 weeks ago and probably won't turn them off until April 2010. Toasty buns are very important. ;)
  7. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    Heated seats in California. Now I've heard it all! LOL Whatever floats your boat. Up here it doesn't get *above* freezing for months and I don't have heated seats! My Jeep did but I got rid of that guzzler... heated seats are nice for *cold* weather...
  8. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Pugsy,
    Used to live in Long Beach (SCAL) for 11 years...I know once my blood thinned I was cold in 45 Degree weather! I hear ya. One thing about leaving them on all the time, I don't know how that would affect the "life" of something like the heaters, but I would think it would be small in the spectrum....but that would be my only thought..
    Wish I was in California now! :)
  9. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Might toughen up that rump roast!!
    I used to live in Vermont, 48 below the year I left. My little Toyota was the only car that started for miles. It had a stick shift and manual choke, other vehicles were plugged in and still would not start. That car would do anything as long as the snow wasn't too deep!
  10. patsparks
    10,664
    567
    Adelaide South Australia
    I wouldn't, it is over 100f outside right now though.
  11. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    Because your butt will catch on fire! And that will make your leg spasm and jam the accelerator to the floor. The massive acceleration will force you back into the seat, increasing the heating effect and beginning a reinforcing cycle of rump roast and runaway acceleration. Then we'll need a warning tag on the seat heater controls, so don't do it!
    [/snark]
  12. TKY
    TKY Member
    232
    25
    Colorado
    Hi Pugsy, There used to be a theory that one should not leave a car A/C on all the time because of the added load on the cars electrical system and battery at start-up. I don't know how valid this concern was, or might still be, or if the same concerns might apply to leaving the seat heaters on when your starting the car.
    Anyone have any knowledge about this concern? --TK
  13. Tideland Prius
    16,532
    Yeah if your car had a 1.0 litre engine and a 6 year old 12V battery
  14. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The car does have an ECU which ensures power steering will get enough juice - first to turn off are rear defroster and heated seats when this is the case. Not sure if this applies when "starting" the car as well.
    Keep in mind, starting the Prius is simply firing up a few ECU's which then energize a relay to the hybrid traction battery. Once that's on, the inverter's DC to DC converter takes over.
    In AZ, the coolness only lasts in the morning, so I don't leave mine on all the time just yet. Maybe in January...
  15. Croft
    Croft New Member
    55
    Dorset, UK
    For men prolonged use of heated seats may have an affect on fertility levels. More here, together with a rather more scientific view than you'd find in the newpapers.
    Fertility in the hot seat
