Any reason not to trust dr prius life expectancy?
Discussion in 'Prius v Main Forum' started by PriusPaddler, Oct 12, 2024.
  1. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    Tried it on 2 cars today. 2nd car had not been warmed up much at all. Had a hard time charging up.
    In the end reported 57% life (2015, 128k)
    Any chance that would be better if I drove it 10 minutes first?
  2. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    First car had been driven maybe 2 miles before testing. 73% (2015, 105k)
    Last week tested one in dealer parking lot after it drove maybe a block. 85% (2012 135k)
  3. Carall
    Carall Member
    228
    Harrisonburg, VA
    The battery pack needs to be warmed up to ~75 f. At ~75 degrees the hybrid computer begins to pay attention to the internal resistance of the modules, as they are warm enough.
    After the pack is warm, charge the battery to 72% and then load it with ~6.5 amps and wait until the charge drops to 40% - this is the end of the test.
    I wouldn't torture the gen3 & gen 4 engine trying to charge the battery pack by stepping on the gas pedal.
  4. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    So the 57% might be wrong if it was colder? I liked the car but for that.
    I'll check the app on my prius hatch. I assume it will tell me temperature.
  5. Carall
    Carall Member
    228
    Harrisonburg, VA
    I'm not sure. I always tested at temperatures above 75 degrees.
    PriusPaddler likes this.
  6. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    I guess that's the difference between testing in VA and MN, lol. Thanks for the info - it does seem like torture to press gas and brake and try to charge it up. Next time, I'll do the test drive first and see if I can't shorten that phase.
