Any way to add the Model 3 radio to a Model 2?
Discussion in 'Prius c Accessories and Modifications' started by blackjack987, Apr 30, 2012.
  1. ROLOPR
    ROLOPR Member
    441
    Puerto Rico
    Can you do a write up of this to clarify all this, I'm lost on where that connector is.
  2. wmo168
    wmo168 Member
    239
    48
    South Florida
    You doing the conversion too? Which connector you are looking for.
    I also want to add a note, you need to check to see your C1/C2 has the Vehicle Speed Sensor wire in the original radio harness, apparently base on the menu all C1/C2 has that wire but when I look at the harness it doesn't.... It is stupid that I need to tap into the speed sensor to the radio back otherwise the Navigation won't work correctly. Now everything is working. I will show you how to do that when you get to that part.. it is easy.
  3. ROLOPR
    ROLOPR Member
    441
    Puerto Rico
    Not yet but try to understand what you did :)
  4. wmo168
    wmo168 Member
    239
    48
    South Florida
    No problem, it is easy...
  5. ROLOPR
    ROLOPR Member
    441
    Puerto Rico
    Now i'm probably clear of why when I installed the Steering wheel pads for the Voice Command the Display and Trip doesn't work. Since the mod that you did probably now should work.
    I need a Prius C radio je,je
  6. ROLOPR
    ROLOPR Member
    441
    Puerto Rico
    Question do you use the display and trip button on the steering wheel for this to show up on the 6.1 monitor??
  7. wmo168
    wmo168 Member
    239
    48
    South Florida
    No, it is completely separate, the connection describe is for you to hit the CAR button on the radio and it has 2 screen to show the trip information and energy monitor.
  8. ROLOPR
    ROLOPR Member
    441
    Puerto Rico
    MM ok, so I still don't figure out why when I replace the Steering wheel pads the DISP and TRIP buttons doesn't work for me.
  9. Fight'n Goat
    Fight'n Goat New Member
    OAKLAND CA
    2014 Prius c
    Can you please show me how you got the energy monitor working. I'm trying to get it working on my c2 with the head unit of a c4. Thanks!
  10. wmo168
    wmo168 Member
    239
    48
    South Florida
    I have the solution on the beginning of this post with picture
    You need to run two wire between the PIN.
    This is to get the CAN BUS information for the Trip and Hybird display
    Radio G78 -9 and G78-10 to Junction connector - 5 and -16 per above pic IMG_2018.jpg,
    This is to feed the speed signal to the unit so the Nav Map can function correctly. Otherwise the map position will jump up and down when you drive.
  11. alphaatomix
    alphaatomix New Member
    Fresno, CA
    I don't see images IMG_2018.jpg and IMG 2015.jpg that you're referring to, can you reupload the pictures for a better reference??
  12. Sccovarrubias
    Sccovarrubias New Member
    Las vegas
    Hello. I am new in the forum, i tried doing the 3 wire
    connector 7 on stereo
    8- I added a pin
    9- I added pin,
    17 - tapped in to SB wire sky-blue
    On the juntion box for wires 5 and 16. I dont think i got the right wires. I added 2 wire pins aswell, did I had to add wire pins or did I need to tap into the existing wires? Do you remember the wire colors?
    For wire #17 I tapped into the speed sensor wire #6 is a blue wire on one of the corners of connector. Is this right?
    I did all this and it is still not working. Does anybody have a close up picture of juntion connector where i can clearlly see where to connect the wires to?
  13. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    306
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I'm getting pretty close to buying a nav OEM head unit for my C2, but I'm still not clear on what needs to be connected and tapped where. Does anyone have pictures on both sides?
  14. wmo168
    wmo168 Member
    239
    48
    South Florida
    You don't tap into any existing wire at the Junction Connector Slot 5 and 16, you need to create a new wire and insert a female pin into the harness so it can be connect since it is a CAN BUS wiring setup to get signal, you have to do the same at the radio harness since the existing wiring is empty for a C2 car. Tapping into other wire will not work and will give you major error.
    To do the feed for speed signal, you also need to create a new wire and insert a female pin into the actual radio harness so it can be connect but on the other end you just need to t-tap from Radio G78 - 17 to Speed Signal cable on the G66-6 IMG 2015.jpg, you ca get the speed signal by one of module under the dash (The low speed audiable control box)
    PriusC_Commuter likes this.
  15. Tim Lillis
    Tim Lillis Junior Member
    36
    Grand rapids
    2014 Prius c
    Did anyone else successfully do this? If so, what did you use for wiring into the junction and the speed side, i have plenty of harness pins for G78, but maybe i am a noob and pins arent used on those connectors? Albeit I have only been able to get to the junction connector as the airbag one seems elusive to me, not sure how wmo168 got to it.
  16. PriusC_Commuter
    914
    306
    2014 Prius Plug-in
    If you are able to figure it out, can you try to post pictures on the process? Someday I'll get around to this project.
Loading...
