Any Way To Adjust HUD Left/Right (Not Up/Down) ?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by gby, Mar 12, 2017.
  1. gby
    gby New Member
    Boston
    New Prius Prime Advanced owner here. Mostly like everything but I have a problem with my HUD display. I have found and adjusted the vertical (Up/Down) adjustment and have that dialed in. But, I have a left/right centering problem. In my normal driver sitting position the right edge of the speed reading cuts off. If I close my right eye I can see the last digit but if I close my left eye it is gone. The left side of the HUD is fine and has plenty of margin.
    I can move my head/body to the left a little and the HUD is all visible to both eyes, but that posture feels unnatural to me.
    So, is there a way to adjust he HUD left and right? I highly suspect the answer is no from the normal user interface since I have seen no mention of it in the manual and the dealer salesman said no. But, maybe there is?
    Has anyone else had this issue with their HUD?
    Can the unit have screws loosened inside the dash on the HUD projector to re-center it mechanically/manually? In other words, if I complain loudly enough at the dealership can this be easily fixed???
    Thanks in advance for any help.
    #1 gby, Mar 12, 2017
    angus and pghyndman like this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Nope...and I noticed its imperfect center when I was test driving as well.
    dalcon95 likes this.
  3. ruby
    ruby Member
    130
    78
    I find it a little too far to the right for me too. It doesn't bother me as much now. I guess I'm getting used to it.
  4. Rightrudder
    Rightrudder Member
    49
    59
    Nazareth, PA
    Same for me. I guess I naturally lean a bit to the right in my car -- but just in my car I swear!
  5. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    But your name is "Right"rudder???
    OMAR SAYEED likes this.
  6. Rightrudder
    Rightrudder Member
    49
    59
    Nazareth, PA
    Good point. That's what my old flight instructor used to scream at me
    OMAR SAYEED and Prius Maximus like this.
  7. White 17
    White 17 Junior Member
    59
    17
    Nor Cal
    Usually the old ones calm down. Maybe not always.
  8. xtins
    xtins New Member
    26
    US
    They way you sit matters, I just happen to be not centered on my seat.
    Prius Prime 2017 - Advance
  9. AdvancedPrimeTime
    AdvancedPrimeTime New Member
    Berkeley, CA
    2018 Prius Prime
    I’ve had EXACTLY the same issue. If I sit perfectly centered in my driver’s seat, I can see the HUD mph projection with my left eye only. My right eye can’t see it at all, so it leaves the image blurred.
    I have to lean left to get both eyes on the mph for it to be clear, but it’s so annoying (!) and feels like Toyota should have a fix.
    I stopped by the dealership today and they threw up their hands not knowing how to fix it. One option they offered was to have me bring the car into the shop and have them go through their entire software program for the Prime Advanced to see if THEY have any control of the left-to-right movement. The other option would be to put in a shim so that the HUD device is physically moved a little to the left but they admitted that it wasn’t a “Toyota solution.”
    Would be nice to hear of someone with a successful remedy.
    #9 AdvancedPrimeTime, Aug 18, 2018
  10. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I found an adjustment in one of the menus. I thought left and right was an option. I forgot where. I will take a look and report back.
    #10 Dennis_MA, Aug 19, 2018
  11. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    One of the attractions of the Prime was the availability of the HUD. My previous car, a 2009 Cadillac STS, came with an HUD which I originally thought was frivolous. However, both my wife and I quickly found that it was a very useful feature, especially when providing GPS navigation info.
    Several Prime owners have commented on the problem of the Prime's HUD horizontal positioning. I had the same experience the first few times I drove the car but eventually I settled into the seat and the problem went away. (See HUD | PriusChat)
    Again, my experience was similar for my first week owning the Prime. I'm not sure the improvement was due to my getting used to sitting differently or with the Prime's seat becoming "broken-in" and more sympathetic to conforming to my body shape and weight.
    I believe the only adjustments are brightness and up/down:
    I think your problem is inherent in the design of the Prime and not a defect specific to your car. If your dealership is willing to try a mechanical fix, it might be possible but it would involve their own creativity and improvisation. Let us know what you do.
    By the way, there is a lot of grumbling that Tesla's new Model 3, which depends almost entirely on its large center-located touch screen display, does not have an HUD or offer it as an option. Go figure.
    #11 Old Bear, Aug 19, 2018
    ruby likes this.
  12. Dennis_MA
    185
    109
    Amherst, MA
    I checked this evening and there was only an up or down adjustment. I think my 2012 had a right to left adjustment. But it is long gone so I can't check.
  13. BrettEG
    BrettEG Junior Member
    Massachusetts
    2018 Prius Prime
    Same boat here - the right side was just barely cut off - I have adjusted myself to get it all.
  14. Old Bear
    712
    1,050
    I can attest to your observation about seating position. I did some further personal research and discovered the following:
    Curlyone, ruby and Tideland Prius like this.
  15. Tideland Prius
    16,683
  16. Ralith
    Ralith Junior Member
    48
    Bloomington, IN
    I just got mine and this is happening to me too, I guess I lean or sit a bit to the right in the seat.
  17. Chris Black
    Chris Black Junior Member
    31
    Arlington, va
    Found this thread while searching for a solution to the same issue.
