Any way to mod the PRNDB panel by the gear shift?
Discussion in 'Prius c Accessories and Modifications' started by Deleted member 111882, Dec 26, 2014.
  1. So I'm getting bored with the panel thingy that has the little letters PRNDB, and I'd like to install something cooler like a laser-engraved thingy. But I have no idea what I'm doing (like I barely use a screwdriver) and I really don't want to scratch up my car. Clear steps and recommendations for cool panels would be great.
    robertmaria likes this.
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i havent done anything like laser engraving. i did change the original bulb into a led.
    its pretty easy to remove everything in that area. you dont even need a screwdriver. you can just pry back each panel and pull it off. they are all clips
  3. Mike500
    Mike500 Senior Member
    2,593
    766
    They make a lot of nice TRD shift knobs. The ones made for the automatic shifter mimic the same shape as the OEM one, maybe covered in leather.
    The best ones are, however, made for manual shifters. Unfortunately, they use a M12x1.25 metric thread, while automatics use a M8x1.25 metric thread.
    Because I've searched everywhere and have found no adapters, I've made my own in my machine shop. IMHO, the manual TRD shift knobs are much nicer looking than the automatic ones.
    You can get special "no damage" plastic trim removal tools at Harbor Freight an local auto parts stores for removing panels. I have several sets.
    Look to Japan for JDM shift panels. Theirs may or may not fit, because their cars are right hand drive.
    You can look to a custom shop that does carbon fiber effect overlays. I've seen them on Cable TV shows.
    51,155
    take it to a speed shoppe and have them do a nice custom for ya.(y)
  5. irrational
    irrational Member
    102
    38
    Tulsa, OK
    Shouldn't be a problem, the gate pattern is the same I believe.
    mertechperformance likes this.
  6. Mike500
    2,593
    766
    Didn't know on the Prius"c." It's different on nearly all Gen II, Gen III and the Prius"v" models.
  7. irrational
    irrational Member
    102
    38
    Tulsa, OK
    I just double checked, and you're correct. It's 180 backwards... so much for that, lol. :)
  8. Mike500
    2,593
    766
    Wish I was wrong, but that's life.
    irrational likes this.
  9. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    on my very much loved Prius c i realize the whole PRNDB thingy is FAKE. they are computer swithches along with fake gear shifters. i would like to yank the whole thing and instead put in some real cup holders for decent sized cups of coffee. it really wastes a lot of space right now.
  10. Mike500
    2,593
    766
    That is probably true with the Gen II and Gen III shifters other than the one on the "c."
    I dissected both the Gen II and Gen III shifters and found X-Y components with magnets and Hall Effect sensors with 5 volts readouts.
    The "gate" on the "c," as with nearly ALL Toyota automatic shifters is much simpler, with only one Hall Effect sensor connected to a cable. The horizontal movements in the shifter do nothing except act as "detents" like the manual push button lock shifter found on cars for years.
    Toyota, for reasons of cost, did not include the more expensive X-Y Hall Effect sensor shifter on the "c."
    IMHO, the Chrysler RAM and 200 shifter with the rotary knob is simpler than ant mechanical stick found on any Gen II or Gen III Prius.
  11. I tried, I was afraid to break or scratch something. (I know, whimpy...) Do you have step-by-step, or a video?
    Yeah all the panels I saw were the Aquas.
  12. Mike500
    2,593
    766
    Got this set at Pep Boys,
    Non Marring Pry Bar Tool Set 24240 | eBay
    Unlike the fiberglass filled plastic ones, these are made of soft and harder polyethylene, which is softer than the ABS used by Toyota on their trim panels.
    The orange ones are softer and more flexible; the black ones are more rigid.
    I've used others, but these make it hard to damage the panels, if you apply steady and continuous force. Stuff breaks with rapid and highly applied pressure.
  13. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    I'm going to paint the grey panel black.
