Anybody have model# for 12 volt optima yellowtop replacement for 2012 pip?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bulldogbob, Aug 26, 2017.
  1. bulldogbob
    bulldogbob Junior Member
    I've seen people mention that they replaced their factory battery with an optima yellowtop, but they didn't mention the model #.
    I inadvertently put this thread in the incorrect forum previously
    49,399
    should be the same as the lift back.
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    I asked Optima why the battery finder app on their website can never find a battery for the Plug-In. They replied that it does not come up on their website because it is "not a starting battery," AND that the yellow-top DS46B24R is indeed the correct match. Now, who has a safe procedure to change batteries without losing most of the saved settings and history of the car? Do it with the car running? Use the jump-start connection under the hood with a 2nd car while powered on? Many years ago I heard of connecting a simple 9v battery to the cigaret lighter, supposedly to supply enough voltage to preserve the radio and clock settings on an average car.
    j12piprius likes this.
  4. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    FWIW...used a "maintenance charger" attached to under hood connections..
    Pluggo and bisco like this.
